orion r68 meta , 100mb lan.
[ROM] LOLLIPOP Tronsmart R68
Thanks for the words.
I have been fighting with it for the last couple of days to try to compile a 64 bit system, that is my first priority, but it has been time consuming. Sometimes it compiles through 5 hours and then fails other times is faster.
painful days
Code:target C++: libskia <= external/skia/src/opts/SkUtils_opts_none.cpp external/skia/src/opts/SkUtils_opts_none.cpp:20:1: error: 'SkSetPixels16Proc' does not name a type SkSetPixels16Proc SkSetPixelRow16GetPlatformProc() { ^ external/skia/src/opts/SkUtils_opts_none.cpp:24:1: error: 'SkSetPixels32Proc' does not name a type SkSetPixels32Proc SkSetPixelRow32GetPlatformProc() { ^ external/skia/src/opts/SkUtils_opts_none.cpp:28:1: error: 'SkSetPixels16Proc' does not name a type SkSetPixels16Proc SkSetPixelRect16GetPlatformProc() { ^ external/skia/src/opts/SkUtils_opts_none.cpp:32:1: error: 'SkSetPixels32Proc' does not name a type SkSetPixels32Proc SkSetPixelRect32GetPlatformProc() { ^ make: *** [out/target/product/rk3368_box/obj/SHARED_LIBRARIES/libskia_intermediates/src/opts/SkUtils_opts_none.o] Error 1 #### make failed to build some targets (02:50:22 (hh:mm:ss)) ####
painful days
[/CODE]
later---cappybob
Originally posted by trungk43 View PostKodi works fine at 4k@30hz, not work at 4k@60hz. Could you please provide new Kodi apk or guide us how to fix it? Thanks
Sent from my HTC One using Tapatalk
It would help if you describe the issues that you are having with 4k@60hz, with example(s) to test so that somebody can recreate the same scenario.
Originally posted by yhaddad View PostAbdul,
Where we can download the recovery TWRP for R68 ?
Thanks!
Post 356
Hi abdul_pt, aren't there any possibility to you to support the Beelink i68 device?. I mean I have one device and I could test and give you some feedback or informatiĆ³n.
If your rom are based on Tronsmart ROM and the only thing that doesn't work is gigalan ethernet port you only have to add that driver to your rom, isn't it?.
Originally posted by Arcangel View PostHi abdul_pt, aren't there any possibility to you to support the Beelink i68 device?. I mean I have one device and I could test and give you some feedback or informatiĆ³n.
This is a hobby, that i do for free. I can do this because of companies like Tronsmart that share sources and from time to time challenge developers by offering sample devices. So i have no intention to even look at anything Beelink related. Sorry
Probably it would be easy to implement support for the i68, but that would mean that I would be supporting Beelink witch i don't.
Hi Abdul. Your work is great but your Beta_1 not working with 1000Gb LAN. Can you make more newly firmware for solving this problem? I checking by myself 3 stock firmware on my R68 2/16GB. From July 20 not working LAN. I think you base your firmware on it. Last 2 (Aug 19 and Oct 15) - LAN working. Maybe you just can compiling new kernel with support 1000Gb LAN module? Thanks for your job.
Originally posted by maximry View PostHi Abdul. Your work is great but your Beta_1 not working with 1000Gb LAN. Can you make more newly firmware for solving this problem? I checking by myself 3 stock firmware on my R68 2/16GB. From July 20 not working LAN. I think you base your firmware on it. Last 2 (Aug 19 and Oct 15) - LAN working. Maybe you just can compiling new kernel with support 1000Gb LAN module? Thanks for your job.
Also Tronsmart's SDK is for 100mbps lan not 1000mbps, so can't even use it.
It is better to just install Zidoo firmware on R68 and everything will just work.
I think the biggest problem is Tronsmart not releasing an updated SDK, so if you make firmware from an old SDK it will be worse than Oct stock firmware.
There are currently 2326 users online. 6 members and 2320 guests.
