Thanks for providing alternate great ROMs!!
[ROM] LOLLIPOP Tronsmart R68
I have not tried your ROM yet. There was an OTA update on my Tronsmart R68 meta yesterday and it seems to fix some issues (power down option, rooted amongst others) I had with the stock firmware. Are you going to look into building a new ROM based on that?
Thanks for providing alternate great ROMs!!Tronsmart Orion R68 Meta
CS968 -> HTC_T018 v4 20131216 with MTK
GM282 (aka CX 919 II aka J22) - dead
Originally posted by abdul_pt View PostThis is build from source, it's not based on anything.
I'm looking in building another one but not from RK SDK since it's pulling this device down. The roms are 32 bits, cortex-a15 and for arm-v7. This one included. There are a few things to optimize.
Sorry but I am a bit confused by your reply. When you say "built from source" what source are you talking about? Are not the firmwares Tronsmart provides the source?
Also, are your ROMS 64bit?
I think he means built from the SDK that Tronsmart supplied.
Does tronsmart indicate if that RK SDK was specific to this rk3368 model? Want to understand if there is way to know if this source matches the stock ROM they provide.Tronsmart Orion R68 Meta
Originally posted by abdul_pt View PostWhat do you mean specific ? The SDK should work with any RK3368 device with little modifications, in fact it should even work with RK3288 and possibly with other older SoC models.Tronsmart Orion R68 Meta
It will probably only work on Wasser Rom, due the partition scheme and because it's only the ramdisk. I have posted one on another thread here but you probably will need to change kernel/resource
Originally posted by abdul_pt View PostCurrently there isn't no Rom running on 64 bits for the RK3368. That i know.
There are currently 4466 users online. 3 members and 4463 guests.
