Ubuntu 14.04 and 15.04 on MK808b Plus
Just tried this on a second 808-b Plus that's been sitting in a drawer and, it works perfectly. Thanks, all!
Have to say I'm shocked at having a *buntu flavor running this zippy on such a device. Wow.
This is now clearly the best option, but the only one that doesn't have a sticky!
Checking, that appears to be due to the Q-and-A nature of the thread. Many FT visitors may not even find out about this! So to fix, wouldn't someone like sammaz, or other contributor here, post this as a How-To? Suggested title:[ROM] [Ubuntu MATE] 15.04 (+updates) Best option for MK808-b Plus
As a help to those already running Linux, here's an enhanced how-to:
(Note: Google Drive downloads much faster so it's set as the default. The LinuxMiniPC file is (of course) identical.)
Code:# For Those Running Linux # Set archive name aname=ubuntu-mate-15-04-s805-standard-0_95_Beta.img.xz # Set download source dlsrc=https://drive.google.com/file/d/0BxdG04mQGssLZkozdll0SDR2Q00/view?usp=sharing # Set known md5 hash (for checking) md5h=0b1c679e0f1ca396945d0f7f878776cb # Change to downloads directory as desired cd ~/Downloads # Be sure at least 8 GB space is available on disk (for extraction) # First determine and set which drive is the SD card. # WARNING: The following assumes SD card is sdc. Check, BE SURE and use what it actually is on your system! # Insert SD card and let it auto-mount, verify which it is (use file browser if needed) and BE SURE. dmesg | tail -n20 mount df -h target=/dev/sdc # Do not proceed unless sure 'target' is correct. # Download xz archive of disk image wget -O $aname $dlsrc # Check download md5=$(md5sum $aname) [[ "$(echo $md5 | grep -o "^\w*\b")" == $md5h ]] || { echo 'Bad download. Try again...'; exit 1 } # Extract image to downloads folder unxz $aname # Prepare SD card by wiping sudo umount $target sudo dd if=/dev/zero of=$target bs=4M # Write image to SD card [[ -f ${aname::-3} ]] && sudo dd if=${aname::-3} of=$target bs=4M sync # Check flash, if desired, by click-mounting the SD card in file browser. Then, power down card/reader, remove and continue at wiki to boot into recovery, flash the zip file, restart, and edit system file to enable higher screen resolution. # Note: Connect a USB keyboard to continue using the device. Bluetooth keyboards can not be paired initially.
Hi there, I know this thread is a bit old but I hope someone can help me out. I want to flash my MK808B plus with Linux but I can't get my stick to boot from SD card. I tried the pin method (reset hole) so many times but it always boots normally. Just to prove that I could actually flash on this machine I flash it with finless rom v1.1. I can't get my PC recognize it either (with Armlogic burn tool). I finally managed to flash it by installing "Reboot Recovery" app from Play Store and managed to get the stick booted from recovery. I successfully flashed finless rom but that's not what I need. I need to flash it with Ubuntu.
Anyone got any idea how to make this booting from SDCard or if anything else I can try? Thank you guys.
Originally posted by astateofmind View Posthttp://www.filedropper.com/showdownload.php/8723bs the module for ubuntu.
Can someone give me the link to this file?
Please help! I really need it.
Originally posted by DanielSB View PostIn case you want to put this on a 4GB MicroSD (e.g. if like me you want to get rid of the Mate GUI stuff and use Ubuntu as a headless server), here's how:- Get the image file; I got _ubuntu-mate-15-04-s805-standard-0_95_Beta.img.xz
- Extract it:
xz -dk _ubuntu-mate-15-04-s805-standard-0_95_Beta.img.xz - Have a look at the partition layout:
fdisk -lu _ubuntu-mate-15-04-s805-standard-0_95_Beta.img
[press w, enter]
sudo e2fsck -f /dev/sda2
sudo resize2fs -p /dev/sda2
sudo sync
sudo eject /dev/sda - Enjoy.
Running Ubuntu on such a small device is great. But it's a pity if such a linux doesn't run stable. And neither this ubuntu mate nor the debian8 are stable.
Here (screenshot) I copied more than 3500 files and more than 35 GB from a USB stick to a HDD. But after 40% done the system froze. The same happened also with Debian8. Maybe instead of a device, which isn't much supported for linux, better I should choose a Raspberry P3. Such a device is very well supported and the OS systems like Raspian should run stable.You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
There are currently 2977 users online. 1 members and 2976 guests.
