Ubuntu 14.04 and 15.04 on MK808b Plus
I got the 1080p working, but still can't get any sound from HDMI. I followed these instructions. If you don't have hdmi sound, do the following:
in /etc/asound.conf replace pcm "hw:1,0" with pcm "hw:0,1"
in /etc/pulse/default.pa replace (uncomment)
#load-module module-alsa-sink with load-module module-alsa-sink
and
#load-module module-alsa-source device=hw:1,0 with load-module module-alsa-source device=hw:0,1
Also, my screen does not show the top or bottom of information, I guess this is called over scan? This was the same with the 720 also. How can I get rid of the over scan so I can see the top and bottom menus.
thanks for all the help you have given.
P.S. I removed the miroSD card and it went back to OpenELEC like it should. Awesome. I put the microSD card back in and it goes to Ubuntu. Again, awesome.
Edit: got sound working now, thanks.
Last edited by clarkss12; 28 September 2015, 13:36.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by Fredhosi View PostSammaz how to install flash on ChromiumPrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by sammaz View Post
That would be a setting in your TV...Like in the settings or picture mode. Find your TV remote
Btw, your instructions were excellent, even a novice like me had no problems, and when I did you solved them for me quickly.
thanks.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
[QUOTE=sammaz;n526074]
6. Flash this .img to your SC-Card using this tool http://sourceforge.net/projects/win32diskimager/ (Thanks Regor!)
sammaz Can you please re-include the linux command in your tutorial as an alternative step. Thanks for the tutorial!
[QUOTE=Dovx;n527329]Originally posted by sammaz View Post
Originally posted by sammaz View PostI have updated the tutorial...Let me know if there are any issues.
Code:sudo dd if=ubuntu-mate-15-04-s805-standard-0_95_Beta.img of=[B]/dev/sdb[/B] bs=4M
Originally posted by sammaz View Post[ATTACH=CONFIG]n527005[/ATTACH]
I made up an installation tutorial here to get Ubuntu on SD-Card and the latest Openelec 5.95.5.2 running from NAND :
John
Looks good, thanks for that, hopefully will get time tonight to update.
I'm looking forward to seeing how Ubuntu runs on the MK808B Plus after having switched from windows to linux 2 years ago. All computers in our house are on variants of Mint 17 and despite it been a windows centric world linux has been so much easier to live with. It flies even on a P4 machine and an old Vista era Dell laptop so have high hope for the little MK!
There are currently 2317 users online. 0 members and 2317 guests.
