Ubuntu 14.04 and 15.04 on MK808b Plus
Originally posted by prahjister View PostTry different power supply
Thanks!!, I did it , no lockups anymore, now i have only problems with wifi, it lost signal (router is 1.5 m away from it) and doesn't work unti I disable it and enable again,I'll try today with some wifi usb adapter. Next I'll try to install linux on external ssd ..
Hello,
I'd like to ask if it's possible to dual boot Android from NAND and Ubuntu from SD card on MK808+, with minimal alteration to the preinstalled Android OS.
I'm a newbie to Android devices, but after reading the topics about MK808+ I've derived the following:
A complete Flash memory image can be overwritten with the USB burning tool. But how can I obtain the preinstalled(or at least modded and working) Android setup, that I can restore with the USB burning tool if things go wrong? Is the hardware common enough for the 'stock' images like http://freaktab.com/forum/tv-player-support/amlogic-based-tv-players/other-aml-s802-s805-devices/21960-rom-download-109k4-stock-firmware-for-mk808b-plus-quad-core-tv-stick-add-usb-lan-support to work perfectly?
I will have to replace a recovery.img file. Is this the binary that executes when I keep the 'reset' button pressed on power up? If it's bad, will the burning tool option stop working? Or does recovery.img execute after button is pressed on power and device is not connected to PC?
I guess that to enable booting from SD the 'bootloader' must be altered? Can the original one be restored like Android restores recovery.img automatically? I guess the burning tool is needed to restore the bootloader?
tl;dr: Can I backup and restore my preinstalled Android setup? If I follow steps 2-15 of the solution by sammaz http://freaktab.com/forum/tv-player-...074#post526074, will it dual boot without my installing OpenELEC at all? What modifications to Android do I need to dual boot, without OpenELEC if possible?
If you follow the steps in the guide on post 14,Do everything apart from step 1 you will have android on the nand & Ubuntu on the sd card
Step 12 will flash a new bootloader so when the sd card in inserted it will boot Ubuntu & with no sd card inserted it will boot android.
Guide from post 14.
1. First Install Kszaq's latest Openelec 5.95.5.2 to NAND.
2. Then, Disable pop-up blocking in your browser.
3. Navigate to https://drive.google.com/file/d/0Bxd...ew?usp=sharing and download the .zip
4. Extract the .zip
5. Now you will have "ubuntu-mate-15-04-s805-standard-0_95_Beta.img"
6. Flash this .img to your SD-Card using this tool http://sourceforge.net/projects/win32diskimager/ (Thanks Regor!)
6. (Alternative for Flashing the image) You can also flash the image using a pre-existing Linux machine.
http://wiki.openelec.tv/index.php/HO...The_Disk_Image
7. When completed, place the SD-Card in your MK808-b plus.
8. Use the pin method when starting ...Get to the "Update from EXT" screen.
9. Choose Update from External
10. Choose the SD-Card
11. Choose the .zip file shown in the SD-Card root
12. Press enter then wait 15 seconds while the new bootloader is flashed.
13. Now power cycle your MK808b-plus
14. You will get the login menu right away...boots in under 20 seconds.
15. User\Password is "minipc"
@blinkone: Thank you very much for the quick reply! I can't try the steps right now, but I will by the weekend.
Just a couple more questions:
Is the bootloader a common piece of software I can extract from any stock S805 ROM out there?
Is there a way to extract the firmware (Android ROM etc.) like I can overwrite it with the USB burning tool?
I appear to have bricked my MK808B + running ubuntu. I had gone in Kodi ,play around a little, added the youtube and weather addons the selected the power button within Kodi and then selected "exit". The system became unresponsive so I then attempted to power cycle the MK. It has not been able to boot since!
I attempted this unbrick procedure #26 without success.
Any ideas on where to go from here? Thanks
Originally posted by mailkit View PostUbuntu works for me including WiFi (but disconnecting occasionally) but Wi-Fi works very well (stable) in openelec
PSU is 5v/1a (very ordinary psu).
Even powers on via USB port of TV
Able to connect mouse and keyboard also. Ubuntu Looks stable. except for Wi-Fi
Originally posted by sammaz View PostI experience the same drop outs and I have excellent Wifi in Openelec. I think that linux is powering down the wifi incorrectly. I am going to try some of the other linux firmware drivers here :
http://archive.ubuntu.com/ubuntu/poo...inux-firmware/
do you know if openelec supports UVC webcams?
There are currently 2332 users online. 3 members and 2329 guests.
