wasser-3.0.0rc2-MK902ii-patch
    Hmmmmmm that didn't work maybe also use misc file and boot seems file system a issue now.
      Ok got it working you can use wasser 3.0.1 to go either with rkm or with Wasser rom. Download both unpack each to different folders and use misc/resource/loader. If you want wasser use 3 files from rkm. Wasser on now testing it
      No go in kodi. Crash ect. Everytime I don't include the kernel it's always screwed up? Maybe neomode can work some magic with this release. Paramiter needs to be 4 gigs min. And looks like they corrected boot issues as re boot working. Not a quick as wasser ui. But a positive step forward for the ricomagic software.
        Keep getting this error waiting for external storage with any Paramiter file I use??
        • neomode
          neomode commented
          Editing a comment
          Think this is cause your Box not Root.
        #64
        Originally posted by gumymoty View Post
        Newer build out MK902_ANDROID5.1.1-20151016.1805= 10.26.2015
        https://mega.nz/#!k0l1UYJR!eOCI8CBfz...u9FykfpUebCvE0
        Unfotunately this build is a step back from the previous one , they set the black level to low instead of high in this rom , for some reason setting the black level to low
        Cause a black level banding for H265 in all rk3288 roms (I think they set it at the wrong level when using high) , in addition this rom still has the UHD problem.
          You got kodi to work? Did you update the supersu ? I don't know if that issue with my try but seems to be an issue with file structure. Kodi wouldn't load for nwcto test levels? ?
            If you are talking to me then yes kodi is working and it worked with and without updating super su , but this is the original rom posted here , i didn't mix it with wasser or any other rom.
              Try this Kodi Build for RK3288.
              Neomode
                I think update binary su screw up root? Wasser firmware faster for sure. It positive step forward from ricomagic but need work.
                  Neomode,can you please upload a wasser 3.0.2 patched for rkm902ii/v5?,thx a lot and regards.
                    Wasser just pumping out fixes to the lollipop release 😆
                      Ok I got 3.0.2 working some artfacting on screens seems to be mouse movement sets it off. Turned off debug and 2d settings seems to have minimaized. Picture better still playing but kodi and other programs loading drives work network and wifi work. Nice speed too. Seems faster?
                        scooter2014 can you share the binary image?
                        thanks,
                        luigi
                          I use 902 Rc4 and 3.0.2 unpacked both use loader misc /resource from Rc4 and everything else from 3.0.2 to get to work.
                            Hi scooter2014,
                            How can I repack the firmware? Can you exmplain me step-by-step (if you can, of course) the exact procedure?
                            Thanks in advance for you support.
                            Luigi
                              Use 2.3 rk tools and un pack each firmware once unpacked move to its own directory and then use the tool to install loader/mics/resource file of the base rom and everything else from the rom you want to port to.
                              There is a step by step on freak tab I'll see if I can find it once I walk the dog 😆
