wasser-3.0.0rc2-MK902ii-patch
Hi Budgetgeek can i ask what files you switched? i used the rc2 and the new wasser rc4 and switched res/misc/peramiter/kernel to get it working. i think some changes in wasser kernel but just curious to the items you used is all. reboot puts in into screwed up screen and same with shut down.
scooter2014 and others.
Here is the patched RC4 for the MK902II.
http://www.freak-tab.de/neomode/MK902II_wasser_rc4.zip
Regards
Neomode
I believe I flashed everything from the download. The folder doesn't have a config, so I used finless tool and swapped out everything in the folder. If you flash the v5 beta as a base, you need to dump it, and then flash rc4 as base and swap in the resource.img/misc.img/loader.bin that you dumped. All of those are in the download.
It does not shut down properly.Currently Inactive on Freaktab.com
I use: MK903V | MELE F10 Deluxe | Roku 3600R
RIP: MK808b | MK809III | PIPO M9 Pro
Regards
Neomode
I own a ENY-BOX Clone:
Chipset: RK3288
PCB board: ENY-Q8P-V10
Seller/Shop: ShenZhen HiDeer Technology Co.,Ltd
Label: OTT TV BOX RK3288 Quad Core Model: EKB328
More Info and photos of pcb here.
Some Artifacting. And I can not test the sound at the moment. But a good flow!
But I really need HDMI-CEC support.
Originally posted by mo123 View PostNo RK3288 stock firmware support HDMI-CEC by default.
You can enable it in the resource.img file that you build when making your own kernel.
I would be very happy about some hints.
Greetings by DhDI own a ENY-BOX Clone:
Chipset: RK3288 & AP6330
Bootloader seems t.b. locked.
But Android 5 (wasser rc4) runs on it
Originally posted by scooter2014 View PostI got a new Ricomagic lollipop rom to test tonight. ill check it out and post results later tonight.
BTW: The wasser 3.0.1 looks very promising too if anyone can patch it for MK902II or HTC devices it could be the perfect ROM going by wasser
Release notes.
Originally posted by opengl1971 View Post
Did you manage to test the new lollipop rom yet ?
Release notes.
new rom mk902ii_5.1_RKM_20151016.img
V V V
V V
V
Originally posted by gumymoty View Postnew rom mk902ii_5.1_RKM_20151016.img , i think that is best rom beter that kk roms for my experency wery satabel in gaming not crash erors like kk roms, i have only 1 problem on my tv box cs 928 , this rom work but after turn off yeastarday, tuday wont pas after optimization apps, starting apps, wai this?
V V V
V V
V
https://mega.nz/#!k0l1UYJR!eOCI8CBfz...u9FykfpUebCvE0
thanks.
luigi
V V V
V V
V
Without a doubt , the best video quality as the output is exactly the same as my PC with nvidia card
I compared them pixel by pixel using frame grab of each then subtract the pixels of both frames , the result
Was a complete black frame which indicates that the frames are EXACTLY the same.
They also solved the black level banding problem of the H265 , again for the H265 the image is at the exact
Brightness (Black level) of my desktop PC , also the stuttering problem is solved , also the RKLib codec
For Kodi Works for the first time on android.
The only downside i see is UHD doesn't work and it's a biggie for me , if only UHD works then it would be the
First perfect firmware for the rk3288 , can anyone correct this using whatever wasser used in his roms to get UHD ?
Originally posted by gumymoty View PostNewer build out MK902_ANDROID5.1.1-20151016.1805= 10.26.2015
There are currently 2522 users online. 0 members and 2522 guests.
