wasser-3.0.0rc2-MK902ii-patch
Originally posted by dados View PostPatched lollipop version wasser 3.0.0rc2 for MK902ii.
Same little problems as wasser 3.0.0rc2 for beelink.
If someone like to try it:
http://www.4shared.com/zip/rEvF4lhNc...-rk3288_b.html
regards
DanielCurrently Inactive on Freaktab.com
I use: MK903V | MELE F10 Deluxe | Roku 3600R
RIP: MK808b | MK809III | PIPO M9 Pro
Originally posted by scooter2014 View Post
I think it's an hardware problem...nand damaged (because too many forced plug/unplug?)
Can't even make a factory reset from the settings (recovery damaged?)...sometimes I even can't go to settings at all
I will go for a new tvbox in few months...no more Rockchip, I/O problemes (as I have rk3188 too)...even if cortex A17 are great...mt8173 interrested me
Originally posted by Plumplum View Post
Thanks for all...I try the bootloader and the 7/8 pin shortcut, no way
Originally posted by budgetgeek View Post
I think you can boot rk3288 from sdcard if nand is empty or damaged.
http://www.mediafire.com/download/9n...Tool._v1.43.7z
unfortunately no SD on my device ;-) thanksCurrently Inactive on Freaktab.com
On your computer or box? The box should have a microsd slot. Plug the microsd into the pc, run the app as administrator and flash rom to card. You might want to invest in a usb card reader adaptor for pc if you don't have one.
That thread I gave you shows how to short the Nan pin memory to get it into mask mode. (Not having a SD card slot means device blows) sunchip crap again. Anyways short pins 7/8 and boot into mask mode you have to have usb hooked to pc and pressing reset at same time as powered up so little tricky
RegardsMany devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by scooter2014 View PostThat thread I gave you shows how to short the Nan pin memory to get it into mask mode. (Not having a SD card slot means device blows) sunchip crap again. Anyways short pins 7/8 and boot into mask mode you have to have usb hooked to pc and pressing reset at same time as powered up so little tricky
Regards
I will try one more time, but I already does it without success (it seems that reset button doesn't work at all)...;-)
Had some testing now this best rom for mk902ii for me. The only way to reboot is pergus reboot app and select soft reboot any else freezes box so I still sat something off in root access.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by scooter2014 View PostHad some testing now this best rom for mk902ii for me. The only way to reboot is pergus reboot app and select soft reboot any else freezes box so I still sat something off in root access.Currently Inactive on Freaktab.com
Originally posted by Zahir View PostWasser Beelink RC4 plus resource.img/misc.img/loader.bin from RKM V5 Lollipop Beta = fast, stable and rooted rom for MK 903V, including wireless ac and all the Wasser refinements. Able to shut down from power menu but not reboot.Currently Inactive on Freaktab.com
There are currently 2812 users online. 1 members and 2811 guests.
