# begin build properties # autogenerated by buildinfo.sh ro.build.id=LMY47V ro.build.display.id=p201-userdebug 5.1.1 LMY47V 20151010 test-keys ro.build.version.incremental=20151010 ro.build.version.sdk=22 ro.build.version.codename=REL ro.build.version.all_codenames=REL ro.build.version.release=5.1.1 ro.build.date=2015年 10月 10日 星期六 11:58:25 CST ro.build.date.utc=1444449505 ro.build.type=userdebug ro.build.user=ider ro.build.host=unbuntu ro.build.tags=test-keys ro.build.flavor=p201-userdebug ro.product.model=AOSP on p201 ro.product.brand=Android ro.product.name=p201 ro.product.device=p201 ro.product.board=p201 # ro.product.cpu.abi and ro.product.cpu.abi2 are obsolete, # use ro.product.cpu.abilist instead. ro.product.cpu.abi=armeabi-v7a ro.product.cpu.abi2=armeabi ro.product.cpu.abilist=armeabi-v7a,armeabi ro.product.cpu.abilist32=armeabi-v7a,armeabi ro.product.cpu.abilist64= ro.product.manufacturer=MBX ro.product.locale.language=en ro.product.locale.region=AU ro.wifi.channels=11 ro.board.platform=gxbaby # ro.build.product is obsolete; use ro.product.device ro.build.product=p201 # Do not try to parse description, fingerprint, or thumbprint ro.build.description=p201-userdebug 5.1.1 LMY47V 20151010 test-keys ro.build.fingerprint=Android/p201/p201:5.1.1/LMY47V/20151010:userdebug/test-keys ro.build.characteristics=mbx,nosdcard # end build properties # # from device/amlogic/p201/system.prop # # Set display related config ro.platform.has.mbxuimode=true ro.platform.has.realoutputmode=true #camera max to 720p ro.camera.preview.MaxSize=1280x720 ro.camera.preview.LimitedRate=1280x720x30,640x480x30,320x240x28 ro.camera.preview.UseMJPEG=1 #if wifi Only ro.radio.noril=false #if need pppoe ro.net.pppoe=true # Enable player buildin media.amsuperplayer.enable=true media.amplayer.enable-acodecs=ac3,eac3,rm,dts media.amplayer.enable=true media.amsuperplayer.m4aplayer=STAGEFRIGHT_PLAYER media.amsuperplayer.defplayer=PV_PLAYER media.amplayer.thumbnail=true media.amplayer.widevineenable=false media.amplayer.dsource4local=1 media.amplayer.startmode=true media.arm.audio.decoder=ape,flac,dts,ac3,eac3,wma,wmapro,mp3,aac,vorbis,raac,cook,amr,pcm,adpcm,aac_latm,rm media.wfd.use-pcm-audio=false media.wfd.videoresolution-type=1 media.wfd.videoresolution-group=0 media.wfd.videoframerate=24 media.wfd.video-bitrate=2000000 media.html5videowin.enable=1 media.decoder.vfm.defmap=decoder ppmgr deinterlace amvideo #add for video boot, 1 means use video boot, others not . service.bootvideo=0 # Define drm for this device drm.service.enabled=1 #used forward seek for libplayer media.libplayer.seek.fwdsearch=1 #fix hls sync libplayer.livets.softdemux=1 libplayer.netts.recalcpts=1 #map volume ro.audio.mapvalue=0,0,0,0 #add livhls,libcurl as default hls media.libplayer.curlenable=true media.libplayer.modules=vhls_mod,dash_mod,curl_mod,prhls_mod,vm_mod #Hdmi In ro.sys.hdmiin.enable=true mbx.hdmiin.switchfull=false mbx.hdmiin.videolayer=false #adb service.adb.tcp.port=5555 ######## UBOOTENV VARIBLES - r/w as system properties ########## # # Now we can load ubootenv varibles to system properties. # We use a special prefix ("ubootenv.var" as default) to indicate that the 'property' # actually is an ubootenv varible. # # A ubootenv 'property' will be initialized during system booting. And when user set # a different value, it will be written back to ubootenv device immediately. # ## prefix of ubootenv varibles - should less than 16 chars. #UBOOTENV MTD NAME #ubootenv.var.bootcmd= #ubootenv.var.cpuclock= #ubootenv.var.gpuclock= #ubootenv.var.memsize= #ubootenv.var.ethaddr= #ubootenv.var.ipaddr= #ubootenv.var.gatewayip= ubootenv.var.outputmode= #ubootenv.var.screenratio= #ubootenv.var.oobeflag= ubootenv.var.480p_x= ubootenv.var.480p_y= ubootenv.var.480p_w= ubootenv.var.480p_h= ubootenv.var.480i_x= ubootenv.var.480i_y= ubootenv.var.480i_w= ubootenv.var.480i_h= ubootenv.var.576p_x= ubootenv.var.576p_y= ubootenv.var.576p_w= ubootenv.var.576p_h= ubootenv.var.576i_x= ubootenv.var.576i_y= ubootenv.var.576i_w= ubootenv.var.576i_h= ubootenv.var.720p_x= ubootenv.var.720p_y= ubootenv.var.720p_w= ubootenv.var.720p_h= ubootenv.var.1080p_x= ubootenv.var.1080p_y= ubootenv.var.1080p_w= ubootenv.var.1080p_h= ubootenv.var.1080i_x= ubootenv.var.1080i_y= ubootenv.var.1080i_w= ubootenv.var.1080i_h= ubootenv.var.4k2k24hz_x= ubootenv.var.4k2k24hz_y= ubootenv.var.4k2k24hz_w= ubootenv.var.4k2k24hz_h= ubootenv.var.4k2k25hz_x= ubootenv.var.4k2k25hz_y= ubootenv.var.4k2k25hz_w= ubootenv.var.4k2k25hz_h= ubootenv.var.4k2k30hz_x= ubootenv.var.4k2k30hz_y= ubootenv.var.4k2k30hz_w= ubootenv.var.4k2k30hz_h= ubootenv.var.4k2ksmpte_x= ubootenv.var.4k2ksmpte_y= ubootenv.var.4k2ksmpte_w= ubootenv.var.4k2ksmpte_h= ubootenv.var.digitaudiooutput= ubootenv.var.defaulttvfrequency= ubootenv.var.has.accelerometer= ubootenv.var.cecconfig= ubootenv.var.cvbsmode= ubootenv.var.hdmimode= ubootenv.var.is.bestmode= ubootenv.var.disp.fromleft= # # ADDITIONAL_BUILD_PROPERTIES # ro.config.wallpaper=/system/etc/default_wallpaper.png ro.com.android.dateformat=MM-dd-yyyy ro.config.ringtone=Ring_Synth_04.ogg ro.config.notification_sound=pixiedust.ogg ro.carrier=unknown ro.config.alarm_alert=Alarm_Classic.ogg ro.opengles.version=131072 camera.disable_zsl_mode=1 ro.app.optimization=true ro.product.firmware=00502001 ro.product.otaupdateurl=http://sorry taken out by me ro.hdmi.device_type=4 dalvik.vm.heapstartsize=16m dalvik.vm.heapgrowthlimit=192m dalvik.vm.heapsize=512m dalvik.vm.heaptargetutilization=0.75 dalvik.vm.heapminfree=512k dalvik.vm.heapmaxfree=8m sys.fb.bits=32 wifi.interface=wlan0 drm.service.enable=true ro.platform.has.pppoe=true persist.sys.dalvik.vm.lib.2=libart.so dalvik.vm.isa.arm.features=default dalvik.vm.lockprof.threshold=500 dalvik.vm.dexopt-flags=m=y net.bt.name=Android dalvik.vm.stack-trace-file=/data/anr/traces.txt
amlogic s905 64bit build.prop
here is sample of s905 64bit build prop bit of a teaser :-)
HTML Code:Bugs are Sons of Glitches!
JustMeTags: None
s905 boot logo
JustMe
Quad-core Android5.1.1 STB Hybrid Hardware CPU Amlogic S905 Quad core Cortex A53 GUP Quad-core ARM Mali-450 GPU up to 600MHz 3D Hardward 3D graphics acceleration Memory DDRIII 1GB Flash Nand Flash 8GB ( 4~32GB Optional ) WiFi Built in 2.4G WiFi Blutooth Optional IR Infra Remote control LED Indicator Power ON :blue; Standby :Red Mould Private Tooling 3G Support most external 3G USB dongle HDMI 2.0 HDMI(1.4 and 2.0 ) to support maximum 4K@60fps
output(HDCP2.2)4*USB HOST 4 High speed USB 2.0,support U DISK and USB HDD 1*TF CARD Support 1~32GB 1*AV AV output 1*SPDIF Audio output 1*RJ45 10/100 BaseT Power DC Adapter ( 12V/1A) Accessories Adapter Gift Box IR remote control HDMI Cable User Manual Software OS Android 5.1.1 Decoder HD MPEG1/2/4,H.265/HEVC , HD AVC/VC-1,RM/RMVB,Xvid/DivX3/4/5/6 ,RealVideo8/9/10 Video AVI/RM/RMVB/TS/VOB/MKV/MOV/ISO/WMV/ASF/FLV/DAT/MPG/MPEG Music MP3/WMA/AAC/WAV/OGG/AC3/DDP/TrueHD/DTS/DTS/HD/FLAC/APE Photo HD JPEG/BMP/GIF/PNG/TIFF Adobe Flash Adobe Flash 10.1 support or above Support Language Chinese , English ,Germany ,Japanese, Korea etc. 24 languages WiFi Hotpoint Support Mouse/ Keyboard Support mouse and keyboard via USB
Support 2.4G wireless mouse and keyboard via 2.4G USB dongleKODI Support local high-definition play, support plug-in installation and play DRM Optional :Microsoft Playready,Verimatrix ,Google Widevine Others support DLNA \AirPlay \Google TV Remote \LAN \Miracast \3D moive Bugs are Sons of Glitches!
JustMe
JustMe
JustMe
Quick overview box s905 - p201 8gb/1gb- cpu - Amlogic S905 Quad core Cortex A53
- gpu - Quad-core ARM Mali-450 GPU up to 600MHz
- wireless is 2.4ghz using realtek 8188etv
- eMMC is 8gb Samsung klm8g1wemb
- hynix ddr chipsets
- OS is 5.1.1 Lollipop
Not much has changed in terms of ddr and eMMC chipsets they still using samsung and hynix as they did with the s802 and s812. The OS was android 5.1.1 built 26.10,2015 and was vanilla with no bloatware or any google stuff added which makes me think it might be 1st gen prototype unit. the unit does have micro sd card slot and also reset switch with 2 usb ports, AV, HDMI 2.0, 5volt input socket.
the unit was not rooted either.
I loaded few apps like youtube, google play services, google play store for tv antutu bench mark kodi 15.2 from kodi site and mx player etc
observation while installing and downloading the unit did manage to get to 50deg when tested with infrared laser temp gun while streaming from the net in sd it idled at 37 to 40degs with room temp being 26deg.
it seemed to play big buck bunny without any issues h264 and again temp stayed relative low around the 40 - 42deg, although I did have issue with h265 via kodi this may very well be aml codec that needs switching off.
I will have to try other version of kodi or even spmc kodi did also boot me out once. I did notice also that while doing second time antutu test it crashed and gave me reading of around 22000 compared to 27500 first time
but then again I don't really believe those figures from that app. also the kernel version is now bumped to 3.14.29 and api level 22..
Youtube still only plays at 720p as a out of the box packaged with vanilla os. I will have to test netflix tomorrow.
overall the unit is cheap and is great if you want to stream only from nas or iptv don't expect to be playing intensive games, units is great for travellers and kind of feels little cheaply made. but still performs well for early firmware release with bugs in it.
pro's- cheap unit to buy for under 40 dollars
- wifi/ethernet perform well
- low temp operating temps due to new cortex A53
- small and light weight great for travellers
- does not have bright led light like the s802 or s812 did great news for light sensitive people
- still early days in firmware development
- no heat sink on cortex a53
- 2 usb ports only
- no bluetooth
- not intended for games with the 1gb unit
- same boring mbox animation and tv launcher no dual launchers
- poor ventitaltion
JustMe
MXQ Plus tear apart tomorrowBugs are Sons of Glitches!
JustMe
cool.. you already have a unit?
What's the antutu video tester score..I'm wondering.. and how is video quality (GPU pentacore)Last edited by mitchell4you; 31 October 2015, 17:49.
Originally posted by JustMe View PostQuick overview box s905 - p201 8gb/1gb- cpu - Amlogic S905 Quad core Cortex A53
- 2 usb ports only
- no bluetooth
@ Mitchel4you --- I will try it some time today I'll actually try it on both boxes
@ Bajjann I - I will also try it some time today what do you want tested what feature on the app
want to try and do the mxq plus review too seems like 2 different versions one is p200 other is p201, also got hold of 29th October firmware which is newer than the one i have 26th October so they are starting to roll out, I believe their will be a mass roll out of these units.shortly.
Also some else has kindly told me they will be sending me.another variant of the s905 with led clock, assuming its similar to a T8Bugs are Sons of Glitches!
JustMe
MXQ Plus:
PCB -> https://goo.gl/photos/QiigMDzfrWV4TByp8
build.prop -> http://paste.ubuntu.com/13046892/
dmesg ->http://paste.ubuntu.com/13046691/ + http://paste.ubuntu.com/13047017/
defconfig -> http://paste.ubuntu.com/13049302/
dtb -> http://paste.ubuntu.com/13049348/
System is still 32 bit, running on a 64 bit kernel just like the RK3368Last edited by abdul_pt; 01 November 2015, 01:45.
abdul_pt far from perfect reminds me of the early s802 days there has been 3 or 4 firmware going of your build prop latest being 29.10.2015
my mxq plus is also same revision board.Bugs are Sons of Glitches!
JustMe
There are currently 3002 users online. 0 members and 3002 guests.
