Yes it does play 1080p on youtube with teh apk mentioned
amlogic s905 64bit build.prop
Originally posted by bajann View Post
Yes it does play 1080p on youtube with teh apk mentionedBugs are Sons of Glitches!
JustMe
Thanks for the benchmark results and testing/reviewing..
Whats the name of the device that sticks out? .. im wondering
-i have seen the ad.. 4k2k video play (but it states it can play 4k2k..not it can hdmi output 4k2k)
Whats your opinion about the video playback quality? (Are there microstutter,lost frames, ect)
Are these devices ready for sell.. or are there to many bugs? (As i see them for 35bucks online)
How is the heat..as i see one pcb without heatsink?
Does it really run 2ghz ?
Cheers
not sure which one you mean the ovel shaped one?
I don't have 4k tv so cannot test that
quality is good for me at 1080p
still bugs in firmware
streaming vids from net or nas has already been answered in previous posts
keep in mind the unit seems to be aimed at lower end asian market
will post 3rd box pcb later little busy atm + public holidayBugs are Sons of Glitches!
JustMe
Originally posted by mitchell4you View PostThanks for the benchmark results and testing/reviewing..
what build duke oe?Bugs are Sons of Glitches!
JustMe
Originally posted by JustMe View Postwhat build duke oe?
currently running kerbers 5.95.5 on a square m8 but i had your 5.95.5 build on there too with same results, 5.95.3 and below 2160p resolution was not working, ever since 5.95.5 its been fixed and output and refresh switching works at 2160p 24/30hz. but im just curious because all the s905 videos i've seen so far on youtube say 4k 60fps video playback is the "big feature" but if it outputs at 3840x2160 30hz then its not really important or different from the older chipset.
905 is replacement of 805 with extra core and being 64bit which ain't being utilizing yet
New soc + new sdk = quite a bit of time before having a stable box.
most current rls is 2.11.2015 romBugs are Sons of Glitches!
JustMe
@mitchell4you: Is that $35 for single units or in bulk? The single unit pricing on Aliexpress seems to be around $50 which is similar to the cost of a reasonable S812 based machine which appears to be better equipped for gaming etc. I don't think that there are many at the moment that will be able to take advantage of the improved 4K support of the S905. If the S905 machines do sell ~$35 then it seems that they would offer decent performance at that price.
third sample box s905
JustMe
been new rls of p201 firmware 11/11/2015. if i get time over weekend i will test it and see if there is any improvementsBugs are Sons of Glitches!
JustMe
Originally posted by JustMe View Posthere is sample of s905 64bit build prop bit of a teaser :-)
HTML Code:# begin build properties # autogenerated by buildinfo.sh ro.build.id=LMY47V ro.build.display.id=p201-userdebug 5.1.1 LMY47V 20151010 test-keys ro.build.version.incremental=20151010 ro.build.version.sdk=22 ro.build.version.codename=REL ro.build.version.all_codenames=REL ro.build.version.release=5.1.1 ro.build.date=2015年 10月 10日 星期六 11:58:25 CST ro.build.date.utc=1444449505 ro.build.type=userdebug ro.build.user=ider ro.build.host=unbuntu ro.build.tags=test-keys ro.build.flavor=p201-userdebug ro.product.model=AOSP on p201 ro.product.brand=Android ro.product.name=p201 ro.product.device=p201 ro.product.board=p201 # ro.product.cpu.abi and ro.product.cpu.abi2 are obsolete, # use ro.product.cpu.abilist instead. ro.product.cpu.abi=armeabi-v7a ro.product.cpu.abi2=armeabi ro.product.cpu.abilist=armeabi-v7a,armeabi ro.product.cpu.abilist32=armeabi-v7a,armeabi ro.product.cpu.abilist64= ro.product.manufacturer=MBX ro.product.locale.language=en ro.product.locale.region=AU ro.wifi.channels=11 ro.board.platform=gxbaby # ro.build.product is obsolete; use ro.product.device ro.build.product=p201 # Do not try to parse description, fingerprint, or thumbprint ro.build.description=p201-userdebug 5.1.1 LMY47V 20151010 test-keys ro.build.fingerprint=Android/p201/p201:5.1.1/LMY47V/20151010:userdebug/test-keys ro.build.characteristics=mbx,nosdcard # end build properties # # from device/amlogic/p201/system.prop # # Set display related config ro.platform.has.mbxuimode=true ro.platform.has.realoutputmode=true #camera max to 720p ro.camera.preview.MaxSize=1280x720 ro.camera.preview.LimitedRate=1280x720x30,640x480x30,320x240x28 ro.camera.preview.UseMJPEG=1 #if wifi Only ro.radio.noril=false #if need pppoe ro.net.pppoe=true # Enable player buildin media.amsuperplayer.enable=true media.amplayer.enable-acodecs=ac3,eac3,rm,dts media.amplayer.enable=true media.amsuperplayer.m4aplayer=STAGEFRIGHT_PLAYER media.amsuperplayer.defplayer=PV_PLAYER media.amplayer.thumbnail=true media.amplayer.widevineenable=false media.amplayer.dsource4local=1 media.amplayer.startmode=true media.arm.audio.decoder=ape,flac,dts,ac3,eac3,wma,wmapro,mp3,aac,vorbis,raac,cook,amr,pcm,adpcm,aac_latm,rm media.wfd.use-pcm-audio=false media.wfd.videoresolution-type=1 media.wfd.videoresolution-group=0 media.wfd.videoframerate=24 media.wfd.video-bitrate=2000000 media.html5videowin.enable=1 media.decoder.vfm.defmap=decoder ppmgr deinterlace amvideo #add for video boot, 1 means use video boot, others not . service.bootvideo=0 # Define drm for this device drm.service.enabled=1 #used forward seek for libplayer media.libplayer.seek.fwdsearch=1 #fix hls sync libplayer.livets.softdemux=1 libplayer.netts.recalcpts=1 #map volume ro.audio.mapvalue=0,0,0,0 #add livhls,libcurl as default hls media.libplayer.curlenable=true media.libplayer.modules=vhls_mod,dash_mod,curl_mod,prhls_mod,vm_mod #Hdmi In ro.sys.hdmiin.enable=true mbx.hdmiin.switchfull=false mbx.hdmiin.videolayer=false #adb service.adb.tcp.port=5555 ######## UBOOTENV VARIBLES - r/w as system properties ########## # # Now we can load ubootenv varibles to system properties. # We use a special prefix ("ubootenv.var" as default) to indicate that the 'property' # actually is an ubootenv varible. # # A ubootenv 'property' will be initialized during system booting. And when user set # a different value, it will be written back to ubootenv device immediately. # ## prefix of ubootenv varibles - should less than 16 chars. #UBOOTENV MTD NAME #ubootenv.var.bootcmd= #ubootenv.var.cpuclock= #ubootenv.var.gpuclock= #ubootenv.var.memsize= #ubootenv.var.ethaddr= #ubootenv.var.ipaddr= #ubootenv.var.gatewayip= ubootenv.var.outputmode= #ubootenv.var.screenratio= #ubootenv.var.oobeflag= ubootenv.var.480p_x= ubootenv.var.480p_y= ubootenv.var.480p_w= ubootenv.var.480p_h= ubootenv.var.480i_x= ubootenv.var.480i_y= ubootenv.var.480i_w= ubootenv.var.480i_h= ubootenv.var.576p_x= ubootenv.var.576p_y= ubootenv.var.576p_w= ubootenv.var.576p_h= ubootenv.var.576i_x= ubootenv.var.576i_y= ubootenv.var.576i_w= ubootenv.var.576i_h= ubootenv.var.720p_x= ubootenv.var.720p_y= ubootenv.var.720p_w= ubootenv.var.720p_h= ubootenv.var.1080p_x= ubootenv.var.1080p_y= ubootenv.var.1080p_w= ubootenv.var.1080p_h= ubootenv.var.1080i_x= ubootenv.var.1080i_y= ubootenv.var.1080i_w= ubootenv.var.1080i_h= ubootenv.var.4k2k24hz_x= ubootenv.var.4k2k24hz_y= ubootenv.var.4k2k24hz_w= ubootenv.var.4k2k24hz_h= ubootenv.var.4k2k25hz_x= ubootenv.var.4k2k25hz_y= ubootenv.var.4k2k25hz_w= ubootenv.var.4k2k25hz_h= ubootenv.var.4k2k30hz_x= ubootenv.var.4k2k30hz_y= ubootenv.var.4k2k30hz_w= ubootenv.var.4k2k30hz_h= ubootenv.var.4k2ksmpte_x= ubootenv.var.4k2ksmpte_y= ubootenv.var.4k2ksmpte_w= ubootenv.var.4k2ksmpte_h= ubootenv.var.digitaudiooutput= ubootenv.var.defaulttvfrequency= ubootenv.var.has.accelerometer= ubootenv.var.cecconfig= ubootenv.var.cvbsmode= ubootenv.var.hdmimode= ubootenv.var.is.bestmode= ubootenv.var.disp.fromleft= # # ADDITIONAL_BUILD_PROPERTIES # ro.config.wallpaper=/system/etc/default_wallpaper.png ro.com.android.dateformat=MM-dd-yyyy ro.config.ringtone=Ring_Synth_04.ogg ro.config.notification_sound=pixiedust.ogg ro.carrier=unknown ro.config.alarm_alert=Alarm_Classic.ogg ro.opengles.version=131072 camera.disable_zsl_mode=1 ro.app.optimization=true ro.product.firmware=00502001 ro.product.otaupdateurl=http://sorry taken out by me ro.hdmi.device_type=4 dalvik.vm.heapstartsize=16m dalvik.vm.heapgrowthlimit=192m dalvik.vm.heapsize=512m dalvik.vm.heaptargetutilization=0.75 dalvik.vm.heapminfree=512k dalvik.vm.heapmaxfree=8m sys.fb.bits=32 wifi.interface=wlan0 drm.service.enable=true ro.platform.has.pppoe=true persist.sys.dalvik.vm.lib.2=libart.so dalvik.vm.isa.arm.features=default dalvik.vm.lockprof.threshold=500 dalvik.vm.dexopt-flags=m=y net.bt.name=Android dalvik.vm.stack-trace-file=/data/anr/traces.txt
There are currently 1542 users online. 1 members and 1541 guests.
