amlogic s905 64bit build.prop
    Hello, I also took a MXQ Plus and I think with PCB p2OO, I would like to understand why
    when you start not it has a classic screen "METRO" but presents the version with the icons of the programs?
    I have a version FW: p20x-userdebug 5.1.1 LMY47V 20151216.194423 V1031 test-keys, there is something new? I saw a version in 2016.
    Can you tell me where to download it possibly my MXQ plus.
    Thank you
      The Sunvell T95 has a virtually identical conf file as it is also based on the p201 board. I was surprised when I disabled the boot video(not animation) in the conf file, the next time i booted the box up it showed an MBOX boot animation.
      Just in case it interests you the latest firmware for the T95 is here: http://bit.ly/1PxY3kM (LMY47V.20151218 test-keys)
      Another question I have: does setting media.amplayer.widevineenable to true have any effect? I couldn't see any difference when checking with DRM info app. I actually had to install xposed with netflix workaround to enable netflix playback on the t95...
        @ eben80
        you say you can install the ROM of the T95 you put the link on MXQplus ...?
        I'm afraid to briccare my box ... has a beautiful operating system, I saw some
        photo.
          Originally posted by Pakbit
          @ eben80
          photo.
          I'm not saying you that it would work. The only thing I'm saying is when I disabled my T95 boot video, a Mbox animation automatically came up in its place.
            Originally posted by eben80 View Post
            The latest firmware for the T95 is here: http://bit.ly/1PxY3kM (LMY47V.20151218 test-keys)
            How did you install that firmware? My "Update&Backup" doesn't detect it as zip or as image. The image won't extract. So I have only two files
            aml_upgrade_package.img and aml_sdc_burn.ini
            Can't find any info about how else to install.
            This box isn't even listed on the Sunvell Website - http://www.sunvell.com/en/
              It's flashed with the amlogic USB burning software.
                Ah cool. I haven't used that yet, other than to try and unbrick another box, I forgot about it. Thanks.
                Hopefully it makes a difference because the way the T95 that I have now is, it is terrible, - Hopefully it is the firmware.
                It's seizing, skipping pages and most apps crash.
                I also have the MXQPlus and that is much smoother in comparison.
                  help ... I brick my mxq plus ... with openlec 64 mx ...
                  or someone can tell me where to get the stock rom
                  .... Grazie..... Non riesco più ad avviarlo.....
                    Hi everyone! I have some questions about my android tv box.
                    I have ott MXQ Plus box, with Android 5.1.1, CPU: Amlogic S905 quadcore 64-bit Cortex-A53...
                    FW:MXQ PLUS-userdebug 5.1.1 LMY47v 20160104.152308.V1031P test-keys
                    What is a difference between MXQ Plus and Pro? Is it the same firmware?
                    I noticed that notification bar and status bar is missing, why? It's strange to me because before I bought this box I had mk808b with android 4.2.2 and it worked
                      Originally posted by JustMe View Post
                      here is sample of s905 64bit build prop bit of a teaser :-) [...]
                      fwiw
                      this s905, and afaik, also recent, android build prop abi are not 64bit one (which is a bit of a pity). Or can someone post a s905 64bit build prop ?
                        So I just got this box, the Sunvell T95 2G Ram model. How do I enable DTS-HD MA in it?? It doesn't give me the option in Kodi unlike my S95 from Tronsmart. The Tronsmart box is using a Vidon XBMC build. HELP!! LOL
