So I got a Minix U1 and wanted to make a EZ root for you guys.
Let me tell you... learning to root via a ZIP file Lillipop was a MAJOR pain in the BUTT!!!!
Lillipop is very different than KitKat was.
So a Donation is appreciated if you like
This is a full proper root including fixing processes!
When you run the SU app for the first time you it will not have to update the SU binary which is unlike other root tools out there for the S905.
On with the show.....
Download the link below.
Unzip the file and put the 3 files on a SDcard.
ezroot.zip
recovery.img
factory_update_param.aml
Insert the SDcard into your Minix U1
unplug the power, wait 3 seconds and plug it back in.
Now this is the important part. We need to boot the recovery you put on SDcard not the internal recovery or the ezroot.zip will fail signature.
Press and hold the power button. KEEP HOLDING the power button until you see the Android man updating.
Release the power button.
The U1 will reboot and your done!
Enjoy the perfect root
Here is the download link:
https://drive.google.com/file/d/0B9B...ew?usp=sharing
Enjoy and now it is time for me to work on a Finless ROM for this box
