Tronsmart MK908 Android 4.2.2 "Official" - Finless ROM 1.5
MK 908 Freezing
Originally posted by TheDogg View PostPlease download the AnTuTu CPU master free from market, open it and try to set the minimum to maximum frequency (1608Mhz) and then click Apply. when I click Apply, the stick it freezes and must forced restart, with this rom.
AW: Tronsmart MK908 Android 4.2.2 "Official" - Finless ROM 1.5
Originally posted by bobbytool View PostMine froze up also. I tried the reset button, no luck. How do you force restart when there are no off & volume buttons that are on a tablet?
_________________________
tapatalked from GalaxyS3
usb to rj45 not working
Originally posted by Finless View PostOK folks... The "official ROM came out last night. So basically I did what I did to the BETA ROM.
Netflix WORKS! Also the kernel #21 in this is far more stable in my opinion.
So once again here is my ROM based on the Official 4.2.2 Tronsmart MK908 ROM.
Note: only difference is by POPULAR DEMAND, I change the size of the mouse pointer.
I am calling this a Finless 1.5 ROM to make sure there is no confusion with the BETA.
Enjoy,
___________________
Features and release notes for my MK908 4.2.2 1.5 ROM:
Features and release notes for my 1.5 ROM:
1) Rooted and new SU and Superuser applied that supports Android 4.2.2
2) Stock ROM was only 2 Gig of APP space.
BUT you also have parameter file options!
There are also 1gb, 2gb, 4gb and 6gb options.
Read below for how to change that in the flash tool.
Realize if you use this 6gb option, internal SDcard will only have about 600 megs of free space!
3) Debloated of junk APPs and Google Apps you can get from Google Play.
I also updated Google Play to the latest version along with standard APPs.
4) As always, full init.d support! If you do not know what that is... ignore it. For geeks that want to use it. It is there!
5) I re-enabled location services. This is now in the settings menu.
Tested and working with all APPs that use it.
Remember to turn off GPS as we have no GPS.
6) I also re-enabled accessibility options in settings.
7) Gameloft fix. This fixes Gameloft games from crashing to the desktop.
Many of them do not run and crash to the desktop. This is due to a license check based on the device.
Special thanks to Christian Troy for inventing this fix. I modded it for this ROM.
8) Build.prop edit to open up the Google Play store to APPs that normally say "not compatible".
I am spoofing a Samsung device that will show almost any APP as compatible.
Yuor device will show up in google play as Samsung device nopt a MK908 or RKSDK! Understand this please.
I also left the original build.prop in the ROM called build.orig.
If you want to go back, just use ES FIle Explorer or a root file explorer and rename build.prop to build.old
Then rename build.orig to build.prop.
Go into settings, apps, all and go into the Google Play app. Clear the cache and data.
Reboot! You should be back to showing up as a MK908.
9) RK Mirroring is enabled as always.
Also new to Android 4.2.2 is Wifi display.
If you have another 4.2.2 phone or tablet you can share your devices screen on your TV.
10) Remote Control using RK Remote APP is now fully supported!
In the ROM kit is a RKRemoteControl.apk.
NOTE: This is a NEW version and will not cause your TV stick to crash.
So if you have already installed RKRemote before you need to un-install it and re-install this version!!!!
You install this on your phone or tablet and now it can remotely control your TV player!
Just put the APK on sdcard or something and install it on your Android phone, tablet, etc.
ENJOY this one! I had a HARD TIME getting it to work!
11) I added a reboot APP that will allow optional reboot options like reboot to bootloader (flash mode).
12) I have adjusted the mouse pointer size by request!
Stock rom was 55x55. The normal mouse pointer is 22x28 which is too small for many.
I made a 35x35 mouse pointer.
If you want to change that more discuss online and I will tell you how to do it.
13) 1080P Kernel if you want it! Tronsmart also released a 1080 kernel.
I have unpacked it from boot and made it a choice in this ROM package.
See instructions IN THE README for how to choose the correct boot.img and kernel.img
720P boot and kernel is the default setup in my flash tool.
For more information ALWAYS read the README in the ROM kit!
Here are the links for Android 4.2.2 Finless 1.5 ROM
ROM -> Tronsmart MK908 Android 4.2.2 "Official" - Finless 1.5 ROM (245 megs)
Enjoy,
Google TV Screen Loop
I have flashed the Rom probably 5 times now and everytime I plug it into the TV it just gets stuck flashing the google tv boot screen on and off.
I've tried unplugging and plugging back in and still the same.
I notice one other user (pitha) on the forum had the same issue, and got no response
any help would be great thanks
Originally posted by rocknroller View PostI have flashed the Rom probably 5 times now and everytime I plug it into the TV it just gets stuck flashing the google tv boot screen on and off.
search the forum for a V3 romcurrent devices(rockchip sucks)
Hardkernel ODROID C1 running android kitkat
Hardkernel ODROID XU3-L Running Linux/openelec (primary media server)
rPi model B+ running nothing ... bricked
The solution for me was to use another power supply then the TV usb
There are currently 2909 users online. 1 members and 2908 guests.
