Normally you don't need to have the loader selected. If you do want to flash the updated loader then click on the eclipses to the right of the boot loader open the ROM folder and select the new boot loader.
Cube U30GT 2 4.2.2 v6 (27 May 2013) 900 supersport ROM
Re: Cube U30GT 2 4.2.2 v6 (27 May 2013) 900 supersport ROM
Normally you don't need to have the loader selected. If you do want to flash the updated loader then click on the eclipses to the right of the boot loader open the ROM folder and select the new boot loader.900Supersport
freaktab developer
stuck
Originally posted by 900supersport View PostNormally you don't need to have the loader selected. If you do want to flash the updated loader then click on the eclipses to the right of the boot loader open the ROM folder and select the new boot loader.
Originally posted by fansdroid View Postfriend,My first initial purchase cube u30gt2, i have problem with my tablet friend,while i install apk after that my tablet is stuck and can't booting friend,and i try to use your rom but,the result is same,if i install apk ,my tablet was stuck and can't booting again friend,what should i do friend?900Supersport
freaktab developer
Originally posted by 900supersport View PostWhat apk is it? Sounds like it may be the problem.what should i do?
I'm really not sure about this one, I've never come across anything like it. Next time you have to restart try using the reboot apk I've built into the ROM.
On the failed start how far does it get, does it show the boot screen and animation?900Supersport
freaktab developer
Originally posted by 900supersport View PostI'm really not sure about this one, I've never come across anything like it. Next time you have to restart try using the reboot apk I've built into the ROM.
sometimes it is stop at the boot screen,sometimes it get to the animation (i wait for 10 minutes and nothing happen).
Originally posted by DarthJabba View PostV2.02 is out: http://www.51cube.com/ch/DownShow.asp?ID=165900Supersport
freaktab developer
I use rkunpack under Linux.
May be worth searching for Wendel tool download, this may work.900Supersport
freaktab developer
Other than downloading the latest firmware from cube and trying that I'm out of ideas. If that does not work you may need to return the tablet.
Sent from my XT890 using Tapatalk 2900Supersport
freaktab developer
There are currently 1620 users online. 0 members and 1620 guests.
