Cube U30GT 2 4.2.2 v6 (27 May 2013) 900 supersport ROM
    Originally posted by fansdroid View Post
    i have tried the reboot apk about five times nothing change.it got stuck,after stuck i restart it,
    sometimes it is stop at the boot screen,sometimes it get to the animation (i wait for 10 minutes and nothing happen).
    Manage to shut off the tablet remanently. Check if it reboots within one minute.
    Now Push Volume+ and plug the usb cable in.
    CAN YOU FLASH A NEW FIRMWARE / Reflash a firmware?
    This is all you need ultimately.
      Originally posted by 900supersport View Post
      I use rkunpack under Linux.
      May be worth searching for Wendel tool download, this may work.
      WORKS! Thank Brian!
      See the code...
      S:\Android World\RK29xxImageTools_v2.1>lua rk29xx_rom_tools.lua
      RK29xx Image Pack/Unpack Tools
      Blog http://wendal.net
      Project: https://github.com/wendal/teclast_tools
      feedback: [email protected]
      Pls input: 1-Unpack 2-Pack 3-Exit
      1
      Pls copy Image file into this folder,and rename to wendal.img
      Notify any errors!
      Drücken Sie eine beliebige Taste . . .
      Reading file header...
      File header: RKFWf
      Read loader's offset
      Read loader's len
      Read update.img's offset
      Read update.img's len
      Output Loader
      offset(0x66) len(0x2F8AE)
      Output updata.img
      offset(0x2F914) len(0x23AE0004)
      Unpack updata.img to Temp folder
      Check file... OK
      ------- UNPACK ------
      package-file 0x00000800 0x00000241
      RK3188Loader(L)_V1.20.bin 0x00001000 0x0002F8AE
      parameter 0x00031000 0x00000267
      Image/misc.img 0x00031800 0x0000C000
      Image/kernel.img 0x0003D800 0x0094C030
      Image/boot.img 0x0098A000 0x00A4C000
      Image/recovery.img 0x013D6000 0x013A8000
      Image/system.img 0x0277E000 0x1EBE2400
      backupimage/backup.img 0x21360800 0x0277E004
      update-script 0x23ADF000 0x000003A5
      recover-script 0x23ADF800 0x0000010A
      Unpack firmware OK!
      ------ OK ------
      Unpack system.img to system folder
      Cramfs 2 , Modify by Wendal Chen.
      My blog http://wendal.net
      Sources http://github.com/wendal/cramfs
      cramfsck: superblock magic not found
      Enable root permission
      Das System kann den angegebenen Pfad nicht finden.
      chmod: cannot access `system/*': No such file or directory
      chmod: cannot access `system/bin/su': No such file or directory
      chmod: cannot access `system/app/Superuser.apk': No such file or directory
      Unpack -- All Done
      /EDIT:
      ZIP Created...
      flashing....
      rebooting...
      cube logo is back...still booting....
      YESSS!!!!!
      Booted to...
      buuaahh.....all that bloatware is installed...lost root...going to CWM to flash install su v1.25
        I should have a ROM kit available tomorrow night.
        Magnifico, next you need to be able to mount the system.img on your PC and edit to remove bloat and add root etc before you flash.
        900Supersport
        freaktab developer
          Thanks for great ROM!
          I saw v8 here ready for download: http://www.freak-tab.de/900superspor...Kit4.2.2v8.zip
          is it possible to upgrade v6 -> v8 w/o data lost?
            Re: Cube U30GT 2 4.2.2 v6 (27 May 2013) 900 supersport ROM
            Well spotted.
            If you have funs CWM on the tab then you can flash via CWM. It's recommended to clear cache and factory reset but you can normally get away without.
            From the flash tool if you are already on pine of my roms reflashing just boot, kernel and system may work.
            900Supersport
            freaktab developer
              flash player
              Hi all!
              I would like to ask you in this lastest ROM is the flash player support play on full screen mod (set as desktop my internet). I really like the 4.2 but from v1.05 firmware there was not any firmware which support play on full screen flash videos. Thanks for reply
                yes friend,i can flash to new firmware,but after flashing i try to install apk,the aplication can work ,then for several time,the aplication stopped working and my cube is stuck ini logo or can't booting friend,i have use many rom but the result is same,,is any problem with my hardware friend?
                  WHAT apk are you installing? Maybe this is the fault.
                    All of apk friend,i have 3 cube u30gt2 before,2 cube i try to install the apk in play store is no problem,but,the cube, i have problem with my tablet friend?
                      1. Tell us what apps you have installed.
                      2. Do all your tablets crash when installing apk's?
                      3. Did you have problems before installing custom roms?
                      4. Did you try an alternative to the google play store?
                      5. What language do you use.
                        I had a a problem with the Cube that is was stuck on loading screen, it has been for 2-3 weeks i would reccon. I installed the new firmware and it worked, however the tablet would not start after and i plugged it in a powersource and now it's not loading. Any help would be much appriciated,thank you.
                        Ps. I'm a complete noob with the tables business
                          Did my ROM ever boot successfully?
                          Is the tablet detected if connected to the PC?
                          900Supersport
                          freaktab developer
                            No the ROM didn't boot at all.
                            The tablet is connected as the rocksub, i used the drivers that was in the .rar file as windows would30GTH and alot of other numbers, can this have something to do with it that it might be the H model?
                              I did the update for the u30gt H one and it worked, THANK YOU
                                Well done getting it sorted.
                                Just to make clear the u30gth is an rk3066 based tablet. This thread is for an rk3088 ROM, I would not expect this to work on the h :-)
                                900Supersport
                                freaktab developer
