Tronfy X6 / Acemax AK838 / Z4 RK3368 / EKB368 Custom Rom
    Ugoos 1.1.3 for Z4 (untested) use RKBatchTool to flash
    Changelog:
    Main changes from previous version:
    0. Changed Bootanimation "CLOSEDone"
    1. GamepadSettings. Now you can easy share profiles. Profiles saving into /sdcard/GamepadSettings.
    2. GamepadSettings. Fixed crash toast bug.
    3. Daydream. Fixed sleep bug in YouTube and other apps.
    4. Daydream. Added ability of disabling wake up from motions (mouse, gamepads).
    5. Daydream. Renamed sleep timer into additional timer. Added а choice of actions (sleep, hibernation, shutdown) for additional timer.
    6. Fixed bug with audioinput in some apps (Skype, wechat).
    7. Added masked HDMI setting (Ugoos Settings -> System -> Masked HDMI).
    8. Improved SystemUpdate app.
    9. Fixed crash of keyboard into VPN Settings menu.
    10. Cast screen now working (Settings -> Display -> Cast screen).
    11. TvSettings. Added check input parameters for File server Settings.
    12. TvSettings. Added multi window switch.
    13. Added ability to enter NTP server (Date & time Settings).
    14. Removed Face Search app.
    15. Updated GAPPS, YouTube, Chrome. Replaced email and calendar apps on apps from Google. Added Play Games app.
    download
    Share-Online.biz is a worldwide operating fileserving project. You're able to serve and share any type of document like pictures, movies and music with us.
      Hi which of the Rom has Fixed BT mic or Camera Mic? I tried yesterday the Russian mod 1.5 for my Z4 Z4_UGOOS_MOD_V1.5
      Everything else seems good but it's a pity I can use my camera but not the mic on it or neither the Bluetooth headset mic
        Guide update
        Z4_UGOOS_MOD_V1.5 to UGOO UT4 v.1.1.3
        1. If it's the first time, you need to install drivers or manuals DriverAssitant connected devices
        2. Run AndroidTool.exe
        3. Switch "function advandced" tab, select the image "ut4_1.1.3.img" Press "Unpack"
        4.Copy UT4_1.1.3\AndroidTool\Output\Android\Image\system. img copies to UT4_1.1.3\AndroidTool\Image
        5. switch to "Download image" tab unsect all tabs except the "system"
        6. Connecting to the computer through the USB OTG port equipment (full guide you can find printed by connecting "ugoos_firmware_upgrade_guide")
        7. Click on the "RUN"
        8. Once the update is complete restart to mode TWRP recovey select wipe
        sorry for my bad english (I use google translate)
          you can have a list of stock and custom ROMs more stable firmware for z4?
          It would be very useful to enclose everything in a post
            Hi All, has anyone made an Android 6.0 rom for the Z4??
              Hello, new guy here. I have been trying to flash some these roms but all i get is Device Test Fail, with rock chip batch tool and android tool. I can upgrade stock firmware just not custom ones. I am in bootloader and i am in loader mode found. Not sure what it is but can't get it to work. Thanks for any help.
                i cant install apk, always says no enough space, but no problem with google play, i can install without problem, i use Z4_UGOOS_MOD_V1.5 and UT4_1.1.4.tv and in sleeping mode the light is always blue. Dont work play, pause from remote control.
                  uff..support for this tv box is dead
                    ???? ups..
                      no fix for spdif turn off when is used for music etc, and auto activate when use passthrought ?
