Maybe if I put a factory update on a microsd card, the device would flash it at boot? That might get me somewhere again.
T428 ALPHA TEST ROM - Frame skipping testing
I´m having some issues getting the script working to change my resolution/refresh rate at startup... I edited it so it would default me to 1280x720p at 50hz but it seems as though nothing ever happens. When I change res with ADB it happens, so that tells me the script hadn´t done it yet. Any pointers?If my work benefits you and you want to help out the cause, feel free to
http://www.hoaby.com/android/donate.gif
BOOYAKASHA Tronsmart! - Back to Alpha Test 1.6
Well, I did it. Opened my case, found two likely looking pins on the Nand, shorted them and - voila - end of bootloop.
Reflashed Alpha test and am now reinstalling apps.
My thanks to the one or two kind souls who sympathized - Moulin1980 in particular.
Hoabycsr, I forgive your kernel. I should have thought twice about it.
I have flashed about 70 kernels that I´ve made to this device in the past week or so... never have I ever had the issue you described on any of my 3066´s or 3188´s... Sorry though if somehow my kernel messed something up for you... hasn´t happened to me yet and I´m constantly rebuilding it and reflashing...If my work benefits you and you want to help out the cause, feel free to
No Worries
Originally posted by hoabycsr View PostI have flashed about 70 kernels that I´ve made to this device in the past week or so... never have I ever had the issue you described on any of my 3066´s or 3188´s... Sorry though if somehow my kernel messed something up for you... hasn´t happened to me yet and I´m constantly rebuilding it and reflashing...
I look forward to having some choices when your kernel is in beta.
haha sounds good.If my work benefits you and you want to help out the cause, feel free to
Originally posted by hoabycsr View PostI´m having some issues getting the script working to change my resolution/refresh rate at startup... I edited it so it would default me to 1280x720p at 50hz but it seems as though nothing ever happens. When I change res with ADB it happens, so that tells me the script hadn´t done it yet. Any pointers?I am absolutely loving this rom , Netflix is without doubt the best and I have tried all the rest. Yes it has a slight stutter although still much better than anything I used before, but its so so stable not one freeze not one spaz out where it goes back to the title screen and always sound and vision not just sound or vision . Im proper impressed. Nice one Bob !
And my vpn works now which is a huge bonus.
I just need to change this resolution because bits of the screen are missing.
I've tried this alpha version and it did not solve frameskipping in MX player for me. I'm using a 720p mkv file which plays absolutely smooth on my MK802iii but it stutters during panning shots.
I've tried all the different firmwares I could find for the T428, none of them had smooth video playback.
Additionally my Logitech C510 usb cam doesn't work on the T428 using any firmware I tried.
I hope this all gets solved one day. Till then I'll have to keep using my mk802iii using Bob's excellent 1.7 2dark4u firmware.
Originally posted by phjanderson View PostI've tried this alpha version and it did not solve frameskipping in MX player for me. I'm using a 720p mkv file which plays absolutely smooth on my MK802iii but it stutters during panning shots.
Great Work. Although for final release I'd prefer:- No Boot Sound Please (Annoying) This isn't Windows Booting
- Use Old Android UI from Finless 1.4a Android 4.2.2
- [Add] Screen Shot in Status Bar [Screen shot from my Galaxy Note 2] See Bottom*
- [Add] Choice for 720p Kernel(with Frame Skip Fix) or 1080p Kernel in Rom Flash Tool of course
- [Add] Nova Launcher as Default Launcher Much Cleaner
- [Add] Not for this release but maybe Future Release "Samsung Multi Window Manager" See Bottom*
- 5GHz works great I want to say better than any of the other previous roms I've tried but that would be an understatement 1080p youtube no freezing to buffer and torrents fly. Thanks
- Antutu 16004
- Bluetooth works ok as well maybe 3 feet (don't feel like its reception though) seems like its not buffering because sometimes its clear at around 8 feet most times not and vice versa.
- I know its ported but the UI looks crazy and kinda buggy missing buttons.
- [My Opinion] 1080p is a waste of resources, device will/would bench higher on 720p Kernel
- I can't seem to get the RK3XXX Mod Tool to work reply here.
- I WILL Donate to someone who can teach me to mod kernels. Ultimately would like to get the 1.92 overclock fully supported for the Tronsmart T428 as well as some GPU Overclocking.
Screen Shot button on the bottom left
True Multi Window Support [Open As Many Windows As Ram Will Provide]
ODROID XU+E
-Galaxy Note 3 [SM-N9005] | Android 4.3 Antutu 35,755
-Hackberry A10 | Dual Booting Andriod 4.1 & Fedora 18
-Tronsmart T428 | T428 Nexus SDK2 Multi-Windows v1.1
-Ouya Gaming Console | -=StockPlus=- ROM
Always Making Time To Learn and Experiment
Originally posted by hoabycsr View PostI have flashed about 70 kernels that I´ve made to this device in the past week or so... never have I ever had the issue you described on any of my 3066´s or 3188´s... Sorry though if somehow my kernel messed something up for you... hasn´t happened to me yet and I´m constantly rebuilding it and reflashing...Devices
ODROID XU+E
Finally had a chance to try this today along with the new strauzo kernel and it worked amazing!!!
Best i have seen yet. HOWEVER, my tv is pretty old now and has major scaling issues. If Bob could add the ability to resize the screen as in his other roms i think we have a winner. looking forward to an update on this (or any other finless roms)
thanks as always!
There are currently 2804 users online. 0 members and 2804 guests.
