MK809II Finless 1.7a ROM
Originally posted by fic123 View PostThe readme says choose from kernel720 or kernel1080 but there is only one file in the download package, kernel.img. Can I use this with both boot720 and boot1080?
Originally posted by fic123 View PostI don't know what version is the kernel. There is no kernelXXXX.img, the name of the file is just kernel.img
If you have a backup of your ROM as you should before you flash other ROM's... you could always test to see what happened. If it doesn't work properly, flash back to your own ROM
I know what XXXX meant.
These are the files I have (from the download link in the first post of this thread)
boot720.img
boot1080.img
kernel.img
misc.img
I don't have backup of the original stock kernel that the device came with. It's my first time flashing android device.
My goal is to get 1080p output, as it was before flashing with finless 1.7a ROM using boot720.img and kernel.img
boot720.img
boot1080.img
kernel.img
misc.img
Just making certain you understood what I meant by the XXXX.... no room for any confusion for whatever reason.
Your first priority is to get a copy of the original ROM.... without that you don't have a fall back plan and if something doesn't work properly... you only hurt yourself. More about how to identify it later...
From reading the first post.. this is only in part a Finless ROM... someone else put it together from bits and pieces and going by what you said... has only provided one kernel and they didn't say which. This may work fine and perhaps somewhere in this thread they actually tell more about it... but I do know you can't simply go by the name given for the device and expect it to be the same as your own device.
Read through the post about the MK808/B clones and you'll see what I mean... The companies selling these things aren't consistent in how they name them... in otherwords, what you thought was one device may not be exactly that device, it may be a fake or a clone which uses different part.
When reading that thread... look at the chips they are describing... they mention the RK3066 of course... but the fakes are all using different Wifi/BT chipsets .... this means they aren't really a MK808/B devices. This happens on many of the different models so make certain your's really is the one you think before you proceed. You may end up needing to post pictures of both sides of the inside boards and ask for help... a little research now will save you a lot of grief later.
Of course, you may have exactly what you think it is... just make certain before you go on.
Originally posted by fic123 View PostFor now I don't want to open my device to see the exact hardware so first I'll try some other ROMs that people say work on MK809 II.
Thanks for the help.
please help i think i killed it
I have had an mk809ii for several months now and had the stock rom on it, was using it for xbmc but found that the hw support even on the tweaked gothem builds was lousy so i thought i would try to flash finless 1.7a that people seemed to be raving about.
i downloaded all the packs required to do this and followed the instructions.
computer found the device and installed drivers
got it into flash mode and installed drivers
rebooted computer and got back into flash mode all fine
clicked flash
the program sent all the info to the device fine
on the tv it showed formatting the three things (cont remember exact text)
then said rebooting
great i thought that was easy
then i waited
nothing
then i took the power out
nothing
then i rebooted computer
nothing
tried pressing reset button on mk809ii
nothing
basically i have no signal to the tv and i cant get the computer to find the device.
im running windows 7 and have mk809ii
is there a way to force it back to flash mode or is it a total lost cause. i loved this little box but just wanted to get it to play movies smoothly.
would really appreciate some advice as id preffer not to have to buy a new one.
if that is the case though can you recommend a better bow that is small and runs hd smooth as butter
thankyou in advance
neil
Originally posted by prdek View PostI've flashed this rom on my device... all works fine but I can't turn on my wifi!
I don't know what kernel must I use to turn on my wifi. here are pictures of my device if someone wants to help me!
tnx in advance!
I can't remember which ROM I ended up using in the end... but that is where the links to different compatible ROM's started showing up....
Originally posted by rdsok View PostLook over in the thread about identifying clone MK808B's ... start with my post #150 and read on... http://www.freaktab.com/showthread.p...l=1#post124714
I installed that one from rikomagic site and all works fine! even xbmc plays hd videos just fine!
There are currently 2235 users online. 2 members and 2233 guests.
