Sunchip Wintel CX-W8 PRO (x5-Z8300)
I've got one of these boxes on order, I intend to put a fresh windows install on when it comes using a USB memory stick. can I ask will that work OK if using the windows usb/dvd tool or does it need the USB or image formatted in any special way?Last edited by moochweiser; 01 April 2016, 15:42.
Received box yesterday. Some notes:
1) My box reports 32-bit Windows 10
2) It reports that Windows was activated first, but after install windows updates, it says "windows is not activated"
3) WiFi has some problems. Windows displays only one wifi network. When I connected ethernet, I saw two networks once, then one network again. Ethernet looks good, but I didn't test it so much
Update: it reports "Windows is activated" today again. Great.Last edited by alex73; 03 April 2016, 09:07.
Helllo
I have a Wintel W8 but thinking of getting the PRO. In the W8 I cannot get the USB be powered off while Pc is put to sleep or shutdown. So my USB HardDisk is always turned on but I would prefer not. I tried 'Allow the computer to turn off this device...' (DeviceManager) and different configs in the power plan but nothing helps... Does the CX W8 Pro have the same problem?
Or i found better way, or usefull way, because original BIOS was one huge unusefull mess!!!
My bricked PC i upgraded thru USB flasher with Tronsmart ARA X5 plus BIOS and its working for last hour without problems and i feel the pc is working much faster then before...
U can download the bios here:
http://ulozto.cz/xFqvPRzg/tronsmart-...ios-160128-rar
Update:
Its working fine but with two problems:
1) Missing audio codec es8316 - NO jack audio
2) Missing Bluetooth
Hi
If someone need, here is my x32 bios dump... And anyone know flash ara x5 Bios flash without flash programer
https://drive.google.com/file/d/0B6w...ew?usp=sharingLast edited by mtnclk; 21 April 2016, 20:46.
And many thanks, its working fine BRO!!
Originally posted by jonyz View PostHello, due to my foolishness BIOS swapped for disabled GOD parameters and now of course no longer in the picture, maybe someone can shoot video where you can see what items and buttons appear and be pressed to drop the BIOS to default? My box is 64bit Win10.
Hi i was had same problem... Everything working but screen not... U must buy flasher with clip and use this one of two bioses what we were posted here...
http://www.****.com/itm/262345065032...%3AMEBIDX%3AIT
http://www.****.com/itm/262367187387...%3AMEBIDX%3AIT
Already I ordered from Bangood programmer https://goo.gl/83LNaX and a special clip https://goo.gl/eHStz1 to connect not solder chip field.
There are currently 1730 users online. 1 members and 1729 guests.
