Sunchip Wintel CX-W8 PRO (x5-Z8300)
Originally posted by Boom21 View PostHi i have the Wintel Cx Pro with Windows 10 64bit installed.Is it possible to install Win 10 Home 32bit with Media Creation tool from Microsoft with USB stick? Yes or no? Thanks
Might be worth making sure that if the box came pre-installed with 64 bit that there are 32 bit drivers available.
You might find that the Windows setup will detect all the hardware and install drivers automatically but it's not a guarantee.
Worth creating an image of the box so that you can easily return to it if desired.
Does it fail with any specific error?
BTW this thread may be of use if you have to manually restore.
https://forum.xda-developers.com/windows-10/general/wintel-w8-pro-z8300-tools-t3373580R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Hello. I am new to the forum. I do not know English so sorry for mistakes. I have a problem. I bought Wintela pro and I can not install Windows 32bit. Probably bios (UEFI) blocks. On the motherboard is a SATA1 socket, Think you can connect HDD?
And here are pics from inside.
You may only view thumbnails in this gallery. This gallery has 4 photos.4 Photos
Originally posted by Davvvi View PostHello. I am new to the forum. I do not know English so sorry for mistakes. I have a problem. I bought Wintela pro and I can not install Windows 32bit. Probably bios (UEFI) blocks. On the motherboard is a SATA1 socket, Think you can connect HDD?
And here are pics from inside.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
I have a Sunchip Wintel CX-W8 PRO (x5-Z8300) Running win 10 64 bit --it works fine when I use it for playback of video channels however if the channel is full hd (1920 1080) the picture is distorted and unwatchable--is this a problem of the video driver-no hd support or as I only have 2giga ram the box is just not capable! --Any new driver would be great
Many thanx
There are currently 1902 users online. 0 members and 1902 guests.
