Sunchip Wintel CX-W8 PRO (x5-Z8300)
Hello. I have a few problems with WINTEL W8 PRO Z8300.
I something touch in BIOS that now I have problem to start up W8 PRO (black srceen).
When I removed heat-sink from motherboard I broken small SMD (SMT) component.
Please help me, I need :
1. Download - working BIOS dump for WINTEL W8 PRO (32Bit orginal or 64bit) --> I order USB CHIP CH341A programmator
2. Help to detect which value and what kind of component is ---> see my pictures (arrow)
3. Screenshot motherboard to recognize color of SMD component ----> see my pictures
If that component capacitor there is guide to color show value (so I need screenshots of motherboard, or someone can tell me) :
Light grey body colour indicates a capacitance which is generally less than 100 pF.
Medium Grey colour indicates a capacitance anywhere from 10 pF to 10 nF.
Light brown colour indicates a capacitance in a range from 1 nF to 100 nF.
Medium brown colour indicates a capacitance in a range from 10 nF to 1 μF.
Dark brown colour indicates a capacitance from 100 nF to 10 μF.
Dark grey colour indicates a capacitance in the μF range, generally 0.5 to 50 μF
Also I need help to order size of component (see picture):
01005
0201
0402
0603
0805
...etc
I asked Sunchip via email, but they didn't replay me.
I decide to fix W8 pro, but I need your help.
Thanks everyone for any help.
Ivo
Large pictures links:
https://s32.postimg.org/ta5ypivud/IM...723_131422.jpg
https://s32.postimg.org/zc3fygd7p/IM...716_162816.jpg
https://uploads.disquscdn.com/images...e24b6b7168.jpg
https://s32.postimg.org/bz5efxx45/IM...716_162826.jpg
https://upload.wikimedia.org/wikiped...Zureks.svg.pngYou may only view thumbnails in this gallery. This gallery has 5 photos.5 Photos
hi there, i have this mini computer with the 64 bits uefi bios (z8300 atom)... i want to install windows 10 or 8.1 32 bits because is come with windows 10 64 bits and is too heavy for the 2 gb of ram, so i want to flash the 32 bits bios to install a 32 bit OS... anyone have archive this in a secure form without bricking the device? best regards
I use this 32bit BIOS. (tested and worked)
http://freaktab.com/forum/tv-player-...314#post568314
Be careful !! You have to know what you are doing !!
Always make your orginal backup BIOS.Last edited by ivota; 13 August 2016, 12:21.
Here is my mod.
Without mod TEMP was about 85-87 C, with mod 65-75 C.
Wifi signals is much better.
I add:
- cooling fan
- heatsink
- external WiFi/BT antena
https://s9.postimg.org/z1u9iv7of/IMG...813_084749.jpg
https://s9.postimg.org/xo2mnk8f3/IMG...813_084824.jpg
https://s9.postimg.org/5clo49dwf/IMG...813_084836.jpg
https://s9.postimg.org/wbpizf0db/IMG...813_084849.jpg
Fan must off if windows went sleep.
Is there on motherboard any point (5V) when Windows went sleep that 5V is 0V?
I didnt find it, so I plug FAN 5V to micro USB (but fan always work except windows went shutdown).Last edited by ivota; 13 August 2016, 12:23.
thanks for ur help ivota, but i have some debts about trying the conversion from 64 bits bios to a 32 one... my wintel pro is different than yours, its have rubber feets and the power button is all black.
i buy it on allyxpress, maybe is from another manufacturer company. your model come with a 64 bits bios and windows from the factory, then you recover the decive with a 32 bit one?? how you break it?
I tried to go from 32bit to 64bit using the Tronsmart ara x5 plus bios (Tronsmart X5 Plus BIOS_160128.rar). Result: Bricked device.
Maybe this firmware is only for 64bit devices already from factory, but not 32bit.
So going from 32bit to 64bit is a no-go. My device is Wintel W8 pro with rubber feet and black button. I have no hdmi output but the power LED is blue and lights on normally. USB power is there just no HDMI output. I will order a USB flash programmer and report back
I really don't know about 32 or 64 bit BIOS.
I have stock BIOS with Windows 10 Pro 32Bit, but when I want to install android-x86 only 64 bit will load successful, 32Bit NOT WORKING.
Also, android-x86 64bit doesn't recognize WiFi and BT devices. Chip is RTL8723BS.
I don't know how rebuild new kernel ? is there complete wintel w8 pro iso?
There are currently 2334 users online. 1 members and 2333 guests.
