Dead MX3
    Your box is a fake!
    In the real box is not a KCA-00x board. In the real box is a board of netxeon.
    Firmware for the real box is not working on the fake box.
    A working firmware for the fake box does not exist on the internet.
    Your fake box you can throw it in the dustbin now. You do not get in order.
    Sorry for my bad englisch. I'm german.
      Yes the box is clone.i know that Odious have the same box like you.The best solution is to extract firmware from working box or get backup from working box and extract u-boot and recovery .
        Odious did you android box work.If it work than please post backup here
          My fake box i've throw in the dustbin. I now have a real MXIII-G box with board of netxeon.
            You know that one of member have made the backup for mx3 n200 clone box.I understand that you hated your fake android box and you have throwed in the dustbin becouse it was bricked.I think at less will help this user to unbrick the box.The backup is.I will try to contact the member to extract the u-boot and 2 other files.At less will be creating a rom for this box.I have mx3 clone box with another type of board and i have bricked and i am angry as you with the clone box.I was unluck becouse i bricked the box 1 month after i confirmed that i recived the box (i bayed from aliexpress).
              Hi Tani just a question I cannot get the software to load from the sd card any advise on how to get it to work would be appreciated
                my advice is that you must use u-boot with BootcardMaker and chose option -partition and format and after that (after chosing u-boot and formating the sd card ) you must put this 3 file aml_autoscript,factory_update_param and recovery.Try all my posted rom and see if the recovery will be displayed without error
                  Download this 2 recovery for your n200 box
                  http://www.freak-tab.de/abdul_pt/aml...8.7.0_N200.img
                  http://www.freak-tab.de/abdul_pt/aml..._N200_emmc.img
                  After you have made bootable sd card using u-boot you must rename this 2 files from TWRP_2.8.7.0_N200.img or TWRP_2.8.7.0_N200_emmc.img to recovery.img and than put one of the recovery.img in sd card and than put 2 other files aml_autoscript,factory_update_param .If the twrp recovery will be displayed on your monitor without errors than you can put zip rom to sd and from twrp select zip rom and try to install
                    use a male a cable to male a cable to power your androd box (connect the cable to one of your usb port on the box and other end of male cable connect to pc).The cable will be used only to unbrick the box.You can't use all the time becouse you may demage the box.
                      if you boot to twrp recovery without error you can go to backup and restore and restore this rom ---> https://yadi.sk/d/IJjLYpDhpoekL
                        Hi Tani666 if I try to open the links in number 53 it opens up a page of numbers
                          I uploaded to mediafire .Download this recovery http://www.mediafire.com/download/fb...c/recovery.img
                            Try only this rom here https://www.dropbox.com/s/vev3liz2yj...0n200.rar?dl=0
                            Extract mx3 n200.rar.Use u-boot with sd boot card maker and put to sd card all file exept u-boot.If the twrp will be displayed on your box than try options restore and backup and go to restore and chose in twrp backup folder the folder 2016-01-26_KOT49H.20150921_test-keys or chose the zip file with the name update.zip.zip
                              One of the member has gived me today the backup rom from
                              Manufacturer: MBX
                              Brand: MBX
                              Model: MXIII
                              Board: n200 (Model: KCA-005, Ver.: 1.0, Date: 150625)
                              CPU: S802
                              GPU: Mali-450
                              RAM: 2GB
                              ROM: 8GB
                              Firmware: KOT49H.20151021 test-keys
                              Android: 4.4.2
                              The only change is that manufacturer is mbx and your is other.Try link in post #58 if you will get error than i will upload the backup rom mbx mx3 n200.The most important think for me is that you can boot to twrp recovery without error.
                                Hi tani I cannot get it to boot to twrp any advise would be greatly appreciated I must be missing something
