I am releasing a build based on the lightweight Firmware in "THIS" Topic.
The Build is still a work-in-progress. All apps are FREE and if you like them, please support the developers and purchase through the google app store.
SquareHome2 can be edited by unlocking the screen. Please see the SquareHome2 Settings for the gesture settings.
Note to users:
- SPMC: If you are using a custom "advancedsettings.xml" file, append to the file, do not overwrite.
- Locked SH2 screen. This is to safe guard against accidental change.
- Weather Live Location. (Automatic update.)
- Network - Currently set to ETHERNET DHCP. Change as you see fit.
- Time/Date - Currently set to Central Africa. Please change to your location.
- Google account needs to be set.
- AnTuTu CPU Master FREE installed and overclocked to FULL BLAST
- AnTuTu CPU Master Free
- DCikonZ
- ES File Explorer
- One Key Boost Memory Cleaner
- Rss Widget
- SPMC with advancedsettings.xml fix for audio-sync problem.
- SquareHome2 Win 10 Style
- System Monitor Lite
- TuneIn Radio
- Weather Live Free
- YouTube
- Download the Z68 Light Build - v0.1B (581MB)archive from Mega.
- Extract and run "ROM_Dumper_Tool.exe" included in the archive. (Please note the INCORRECT and CORRECT screenshots!)
- Hit "RUN" and wait. The dump will take a while as the images become quite big once extracted.
- Your system should restart once after connecting to the network and the desktop has been configured.
- Please ignore the "restarting too fast" generated by CPU Master Free. It will only happen once.
cyber7 (aka Aubrey Kloppers; Cape Town; South Africa)
Screenshots:
- Rom Dumper Tool - INCORRECT: Please make sure that you have connected your USB Cable after RESETTING and HOLDING THE RESET BUTTON on your device.
- Rom Dumper Tool - CORRECT: Please make sure that you have connected your USB Cable after RESETTING and HOLDING THE RESET BUTTON on your device.
- Desktop:
