Android Marshmallow on RK3368 -> BOX64_v170117
Based on above instructions, I created mmallow box image and flashed but the AppStore app is missing. I used lunch rk3368_box-userdebug configuration. Do I need to do special configuration to compile the code? Please guide me.Last edited by muvva.mv; 05 April 2017, 19:55. Reason: Google store app is missing. How to enable google store app in MMALLOW tv image?
Originally posted by followmsi View Post
This default view is sorted by date ..
It's time for Nougat anyway
CheersYou had to say that now i check daily....
Originally posted by muvva.mv View PostI upgraded MMALLOW image into the Geekbox. I downloaded .apk files and installed it but not able to open and it is not showing in location where all apps are located. Does Geekbox supports only pre-installed apps?
Yes, you can install .apk files as well.
Maybe you have to allow "install from unknown sources" first.
Dont understand your question ... the installed apk will be installed into /data/ folder like all the other apps too.
In /system/preinstalled are the preinstalled system-apps.. But the installation of those apps and all the related files are moving into /data/ partiton too.
system partition is normally read-only !
Hope this helps ..
Cheers
Ahhh Geekbox site blog gone to crap.... so looking dim for this device I was hoping some more support for the landingship side but toast now.... not even being moderated so crap posts everyware.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by scooter2014Ahhh Geekbox site blog gone to crap.... so looking dim for this device I was hoping some more support for the landingship side but toast now.... not even being moderated so crap posts everyware.
Even they would release geekbox 2 with top hardware - not sure if it's the right choice anymore.
The china market .. live fast and die young
Cheers
Hmmmm maybe we should grab some firmware and reload it seems like links starting to expire and firmware disappeared from geeks site.
Sad to see the site get taken over by ad bots ect. To nad seemed like good project.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Yes it is a shame about the state of the continual spamming on the Geekbox forum as it will prevent people from getting at the useful information, which it turn could spell certain doom for interest in the product.
I did alert them to it a few days ago though, so hopefully they will simply remove everything at start afresh.
Here I am, asking for Followmsi's precious help or whomever may know. Problem: I'm using the dual boot version of the release by Followmsi this topic is about. I recently bought a Landingship (the price now is ridicuolus... ) and installed the Geekbox board on it. But the headphones jack doesn't work. I don'know if the SPDIF does, but nothing happens when i connect my hp to the jack. I've read that everything should work correctly with his MMellow release, so the question is: could it be 'cause I installed the firmware on the Geekbox board alone, not connected to the Landingship, and thus the drivers didn't install? USB hub, SATA and IR on the Landingship work flawlessly (well, sata not properly like a charm...). Where am I wrong? Any help appreciated!
P.S: I'm not afraid of using shell, if necessary, but I'm far from beeing at ease with linux or android...Last edited by amarkorder; 19 July 2017, 10:35.
Originally posted by scooter2014 View PostHopefully followmsi can re do his one drive links.
Only the google drive folder is working ..
https://drive.google.com/drive/folde...1cyWW9yRy1QMGc
Best reagrds
EDIT:
I was able to re-enable the one drive folder too .. but only 5GB of 15GB are left
https://onedrive.live.com/?authkey=%21AFr5FjilNqmzqsk&id=5842EE9E65C3FAF6%21107&cid=5842EE9E65C3FAF6Store photos and docs online. Access them from any PC, Mac or phone. Create and work together on Word, Excel or PowerPoint documents.
Originally posted by amarkorder View PostHere I am, asking for Followmsi's precious help or whomever may know. Problem: I'm using the dual boot version of the release by Followmsi this topic is about. I recently bought a Landingship (the price now is ridicuolus... ) and installed the Geekbox board on it. But the headphones jack doesn't work. I don'know if the SPDIF does, but nothing happens when i connect my hp to the jack. I've read that everything should work correctly with his MMellow release, so the question is: could it be 'cause I installed the firmware on the Geekbox board alone, not connected to the Landingship, and thus the drivers didn't install? USB hub, SATA and IR on the Landingship work flawlessly (well, sata not properly like a charm...). Where am I wrong? Any help appreciated!
You need to compile a new kernel with the "configuration" you need .. either with landingship support or wiithout.
Cheers
There are currently 3272 users online. 0 members and 3272 guests.
