NEOTV CROM for Flycast MK809III - UG007B - QC802 - Cloudnet Go CR9
Thank you Neomode for this ROM.
I flashed it onto my CR9. It works quite good as far as i have tested it.
The next days i will try to do some testing with my external hardware.
Antutu gives the same result as the original rom: ~ 15.300 points.
I will keep you informed about my testing the next days.
Cheers (Danke und Grüsse)
Löwenzahn
Originally posted by neomode View PostI am making an Update today.
Must Tweak the Speed Step and other things.
May it is a DRM Problem with Netflix and Android 4.2.
What I need is a Netflix Account to Test but I am not in the US :-(
May someone can Setup a 30Day Test Account for me ?
Neomode
Originally posted by sam321 View Post
This alone (along with the hinted Wifi improvement and Bluetooth working) would be enough to get me to update to this!
yes use this Rom and a 1080p kernel from here http://www.freaktab.com/showthread.p...kernel-is-here
Originally posted by bjd View PostRead it's something to do with the player they use and android 4.2 even cm10.1 needs a work around.
Which by the way works well with your rom if anyone's interested see here http://forum.xda-developers.com/show....php?t=2185130. Great rom works very nicely with the above sam321 1080p kernel, thanks sam321
I installed the Xposed framework + the netflix override, and I confirm this fixes the "split screen" issues, but by reverting to the old player, it ends up in a "buffering" screen after maybe 1 minute of playback, which is exactly what I've experience on any 4.2 rom so far on the mk802 IV.
So, for me, this rom does not fix Netflix as far as I can tell.
It appears to me that as soon as Netflix tries to send HD content to my device, the problem appears. So, strangely enough, when my Wifi signal is not great, the movie plays ok in SD, but as soon as it tries to go HD, boom, inifinite buffer issue (which is the same issue as on 1.81 btw, so no big surprise here)
I'd love to get more feedback from other people, as I am surprised to see that this fixed the issues for someone but not for me.
Or, should I install sam321's kernel? Edit: nope, tried that as well, still the same issues with Netflix.
Neomode: what exactly is the Netflix patch you made, if you don't mind explaining?
argon0: in the "rockdev" folder, replace the kernel.img with whatever kernel file you want to install, then install as usual with the rockchip installerLast edited by wololo; 22 June 2013, 08:57.Review of the MK802 IV
My list of 10 "Must Have" apps for your android mini PC
Tutorial: how to setup Unblock-US on your mini pc (to watch Netflix outside of the US)
Originally posted by wololo View PostI just have to say I didn't experience this. For me, Netflix keeps buffuring.
Sixaxis Controller is not working for me
https://play.google.com/store/apps/details?id=com.dancingpixelstudios.sixaxiscontroll er
I first thought that maybe I do something wrong, but tried the same procedure with my TF101 (running a modded CM10) and it worked. Not sure what goes wrong on the CloudnetGO.
Steps:
- Paired controller in the app (verified later with the PC pairing tool)
- Start
- Press power on the PS3 controller
- All lights keep blinking ...
Anyone any ideas?
Thanks.
Originally posted by bjd View PostHi woholo, are you definitely using the cm10.1 work around for the dinc from the link as there is another one which has the same result you described.
I'm running into other issues, but yes, Netflix seems indeed to work now.
I've been using the wrong workaround all along, now I'm wondering if it would work with the default rom as well, after all...Review of the MK802 IV
Originally posted by brAIndamaged View PostSixaxis Controller is not working for me
Steps:
- Start
Anyone any ideas?
Thanks.
Device bricked
Originally posted by sam321 View Postyes use this Rom and a 1080p kernel from here http://www.freaktab.com/showthread.p...kernel-is-here
There are currently 1512 users online. 1 members and 1511 guests.
