NEOTV CROM for Flycast MK809III - UG007B - QC802 - Cloudnet Go CR9
    AW: NEOTV CROM for Flycast MK809III - UG007B - QC802 - Cloudnet Go CR9
    Next week there will be an Update of this Rom. I hope to fix the failures
    Regards
    Neomode
      Regards
      Neomode
      Hi
      You did an awesome job, congratulation for that, it works great on my CR9.
      I have the new version I think because I don't have WI-FI.
      Will your new update fix that?
      Thanks again for your great job.
        Originally posted by kifo View Post
        Hi
        Thank you ! If you have it with the New Wifi Chip than go to the tread for the New MK802IV with new Wifi Chip and Flash this with Kernel1.img.
        This should work for you.
        Neomode
          Neomode
          Hi, thanks for replying.
          I tried to use it but it didn't boot, kept stucked in booting screen. Then I tried using the one that is in this thread but I used the Kernel1.img from the other one and that worked and I have WIFI but Bluetooth is off.
          The other thing is that Netflix works wierd, the image is like larger than the screen so it looks wierd, like 2 images one on top the other, maybe Netflix thinks I have a bigger resolution.
          Do you know anything about that?
          Thanks again for everything man.
            QC802 2G/16G netflix doesn't work
            I can't make it work NETFLIX keeps over framed. Try several times to no avail. Any help
              Man, I fixed it, I follow this link and Netflix works awesome, now I'm happy, except for Bluetooth, if that worked this would be just perfect, I could play emulators with a PS3 controller from my bed.
              Let me know if this worked for you.
              Well, thanks to Entropy512's help, I was able to modify his Xposed hack to work on CM10 (based on Android 4.1) and CM10.1 (based on Android 4.2) for the Incredible. Using the newest Netflix app and it's working well without issue. It's easy to...
                heroes of order and chaos not working here
                gameloft games troubles
                i can be your tester
                mk809iii
                with rom 4.1 this gameloft game works
                i have a good connection speed and i like to help
                i can test
                thanks
                  I really like this rom, thanks for sharing! Installed it on a UG007B and it runs much better than the original firmware.
                  Only Wifi and Bluetooth stopped working, so I flashed the Kernel1.img from the thread "MK802IV New Wifi Chip AP6210 - Neomode Custom Rom Version 1.0" and that solved the problem (BT is still an issue, but I don't need that anyways).
                    omg, i will try to do the same thing to use finles but with this kernel.
                    i hope it work here. you give me a good idea hehehe
                    after i edit and post if it works
                    ___
                    do not work
                      Try this Rom should Work also.
                      Neomode
                        thanks, downloading
                        5 minutes, ehehehe
                        i will try to re-download, i had an error unrar 1080
                        i have flashed with error and it is booting ... i dont know if it is running ok... i will use it today and at night i can talk some about issues, thanks! you had a great job!
                        rk remote controller working. my lan to usb is working very well. now. iam downloading heroes of order and chaos. i hope it works =)
                        ______it is no working =(
                        Just at 4.1 with no rkremote =(
                        How to play heroes Of order and chaos ? It is bootlooping
                          Where is twframework-res.apk to be edited?
                            Hello Neomode,
                            I want to ask you about the new Rom for the old CR9, Flycast MK809III etc.
                            Thanks for your work, i want to switch to your ROM because your work sounds good.
                            Hallo Neomode,
                            mein Englisch ist nicht so gut, dehalb nochmal auf Deutsch:
                            Ich möchte mich schon mal für deine Arbeit mit dem ROM bedanken, und wollte nur mal fragen, wann die neue Version dann kommt.
                            Gruß
                            Matador
                              Hallo
                              Ich Arbeite an den letzten Bug Fixes,
                              dann sollte es soweit sein.
                              Denke so zwei Tage noch.
                              Neomode
                                Hallo
                                Neomode
                                Hey, how to do a gameloft fix?
