OpenELEC for Inpic i7
    Originally posted by INPHIC - Jim View Post
    Hi Balbes,
    May I know? What's the OpenELEC version you are working for Spot i7?
    Hi Jim. Tested the Openelec on the Spot i7. Works with USB and SD card. Doesn't work yet output audio via BT, everything else works.
    Tested the i7 on Linux. Works. Soon uploaded on the website ready images with multiple systems (Debian Ubuntu, Altlinux).
      The version number of the OpenELEC is 6.95.3.7.0. It works very well, remote too.
      Hello Balbes, Really happy to see Ubuntu on the list.
      Thanks for your continuing efforts
        Uploaded on website version of Openelec collected on stable branch. It all works except the built-in BT. When you first start will auto-expand the second section. The first start takes more time.
        Посмотреть и скачать с Яндекс Диска
          Excellent, and working more testing to do.
          WiFi, 2.4g Ethernet, BT Dongle all good.
          As mentioned i7 will a reboot after first boot to allocate/format rest of free space on SD/USB stick being used.
          Cheers
          Couple of drooped/skipped 2.4g WD DUO using USB2 HDD attached to DUO bit sluggish at times but smooth Video and Audio over BT. Click image for larger version
          Last edited by trebor; 19 May 2016, 03:52. Reason: My 5ghz router on 2.4g this unit does not have 5g
            this spot i7 runs like crap as is... is it possible to load openelec directly to the box
            Three days of testing can save 10 minutes reading manuals
              also... are there instruction somewhere on how to boot this openelec from the usb?
                If you make changes in the body (for normal ventilation), replace the radiator, i7 works well enough.
                  would this openelec fw you have load to the box using the usb_burning tool?
                    The first step in the instructions. The second step is to record only the image. Or what files do not change. Take the image from the folder "stable". OpenELEC-Amlogic.arm64-SPOT_i7-7.0-devel-20160518131625-r22293-g8448589.img.xz
                    http://freaktab.com/forum/tv-player-...thod-and-files
                      While this version does not.
                        okay thanks balbes150, i will give this a shot.
                        Please let me know if it is possible to flash the box itself with OpenELEC-Amlogic.arm64-SPOT_i7-7.0-devel-20160518131625-r22293-g8448589. come available
                          Originally posted by balbes150
                          Step 1.) Modifying u-boot.
                          Needed for Step 1, a.)balbes150's update_uboot.7z. file. NOTE: This file is for the Vega S95 box, don't worry it works fine for the Inphic i7. b.) a FAT32 formatted SD card(Class 10 or better) or USB flash drive.
                          1a.) Extract update_uboot.7z to an SD card or flash drive. This results in two files on the card or flash drive, aml-autocscript and aml_autoscript.zip.
                          1b.) Insert the card or flash drive in to the i7 running Android.
                          1c.) Open the Update and Backup app, under the "Local" update section, click select. A list will appear, select the file named aml_autoscript.zip. Click update.
                          The i7 will reboot, you will notice little other than a few screen flashes(be patient) and then the i7 will reboot to Android. Remove the SD card or flash drive.
                          End Step 1.
                          I did this, then i used win32 disk manager to create the openelec thumbdrive.. "i could not copy s905_autoscript or dtb.img to the thumbdrive i just created for openelec" see attached screenshot
                          inserted thumbdrive.. booted my i7 and nothing happened.. just went into android
                            View this topic. It will tell you exactly what to do and how. The first step is exactly the same. The only difference in the original image file Openelec.
                              boom... got it thanks.
                              Again.. if anyone can tell me how to get oe only on this box that would be much better for me
                                Look at this website. No are no guarantees. There is a risk to brick.
