OpenELEC for Inpic i7
    All things OE
    I understand correctly, this is the UART connector ? What it the sequence of contacts VCC Rx Tx GRN ?
    Understood. Hooked up the console. Labeling was under the sticker.
    I had to just look at the next picture in this topic.
      This is the configurations of the pins:
        Good news - collected the working BETA image for Openelec with i7. Works with SD and USB. Uploaded to the site. Try it at i7.
        While remote control is not working. Need file remote.config from the main firmware. Inphic can you help me to get it ?
          Here it is: Download SPOT_i7-remote.config
            Inphic
            Downloaded. Thank you. Will include in the Assembly.
              Uploaded the not much modified file remote.conf . Work with him the main buttons of the native remote control. This file should be placed in a storage directory/config. You can use SAMBA.
                so this works good other than the remote?
                Three days of testing can save 10 minutes reading manuals
                  Update: The IR remote works well. So too does Eth and WiFi. Other than internal Bluetooth not working, OpenELEC is working very well on the i7. balbes150 has made this easy to try since it boots and runs from an SD card or USB flash drive/card reader. Class10 SD card or better recommended. That being said, I have seen it run successfully from an old Class4.....I was curious.
                  Linux too, but that's another conversation.
                  Many thanks to balbes150.
                  Last edited by RISCy Dude; 14 May 2016, 03:10. Reason: Update: Results from testing the IR remote with the latest remote.conf.
                    New image BETA_spot_i7_openelec_20160514.img .
                    Fixed external BT. Please to those who have external BT to check the work.
                      Pulse 8 CEC adapter error kodi on boot previous version also
                      BT Connects using dongle. No audio unable to change setting-system-audio output device. Default (aml-m8audio Analog)
                      Video output:
                      Resolution change to 1920 x 1080i or p many small images on screen can’t see image messy (wrong refresh rate)?
                      Cheers
                        Further to the Video Output resolution,
                        Appears i7 was stuck in a 1280x720 mode, OE could not force the change to 1920 x 1080, and when it did was a mess
                        Running up Android then back out to OE I can now use 1920 x 1080.
                        Was also testing a version of Linux/debian, runs in a low res mode and may have contributed to this phenomena.
                        Well that's my excuse and sticking to it (for now)
                          Perhaps this is the result of the video avtofreyma. With the audio output through pulseaudio - I understand. This is the result of incorporating the latest patches from the main GIT Openelec.
                            Yes plenty of variables to add to the confusing.
                            By going to Android and forcing 1080@50hz OE now defaults that setting and can be altered easily.
                              Hi Balbes,
                              May I know? What's the OpenELEC version you are working for Spot i7?
