OpenELEC for Inpic i7
    Originally posted by balbes150 View Post
    If you don't mind, would you check this option.
    https://yadi.sk/d/FPNqTx9asrgEM
    This zip worked on the i7. I did not change anything with the zip, just selected it from the Update and Backup app.
    WiFi, Eth look good.
    Internal BT no go, external BT paired fine with my phone.
    Audio good, DTS and HD audio work well.
    Since I assume this zip was for the S95 Pro, the i7 IR remote does not work, but the S95 remote does work.
    You have covered how to fix this, so repeat not required.
    Nice work, specially considering you have no i7 or S95 Pro.
      Thanks for checking. Now I can be sure that the image for Pro work and i can collect the version for the i7 Spot.
        Make and uploaded the archive to install to the internal memory Spot i7.
        Посмотреть и скачать с Яндекс Диска
          Excellent, I will give it a run tonight and report my findings.
            Getting black screen with this one.
              Thanks for checking, I'll look for the error.
                I have flashed the i7 back to Android. Ready to test again when the time comes.
                  Upload a revised version. You can check it out.
                    Success. Working very well here, including the i7's remote, WiFi and Eth.
                    I get Pulse eight CEC error, but I am not connected to a CEC capable display, so that is probably the reason for that.
                    This is going to make many i7 owners very happy.
                    Thank you for all the excellent work.
                      Thanks for checking. Internal BT is not checked ?
                        My apologies, I forgot to include my results for BT. No go on internal BT. Was able to connect using an external adapter.
                        I will be ready to test revisions.
                          Hi all, I am not at home at the moment and will be away until the middle of August.
                          I would like to test these files on my i7 but the wifi here in the lodge will not let me download from the links provided.
                          So could some kind person upload to dropbox or alike.
                          Bought the i7 and my computer gear with me to Adelaide while my mate has cancer treatment.
                          Thanking you in advance.
                          Cheers
                          Kevin
                            Cheers
                            Kevin
                            Can send the file by email. Its size is 112 MB. If this is satisfied, write a personal message Your email.address.
                              10 minutes or so Kev I will PM you
                              Cheers
                                Hello Kevin1341, I hope your mate's treatment goes well. Many have been touched, directly or indirectly by that nasty disease. Good luck to your mate with the treatment and its side effects. It will be much easier on them having you there.
