FTMC Jarvis 16.2.31
I use Cloudnetgo CR19 4GB/32GB Rockchip RK3399(171121) [rooted] and install [FTMC-16.2.31-armeabi-v7a-RK-Version].
When I use FTMC to play video file with "Accelerate RKCodec ON", FTMC always closed.
I found the LOG files in path: /sdcard/Android/data/org.xbmc.ftmc/files/.ftmc/temp/
I don't know these files are helpful.
But I have another one Android TV BOX [H96 MAX Android 7.1.2 4Gb/32Gb - SCV1 Beta] with FTMC-16.2.30 ,that is very useful for any video file.
How to solve this problem ?
Originally posted by nanpan View PostI use Cloudnetgo CR19 4GB/32GB Rockchip RK3399(171121) [rooted] and install [FTMC-16.2.31-armeabi-v7a-RK-Version].
https://drive.google.com/file/d/1JKC...ew?usp=sharing
https://drive.google.com/file/d/1nom...ew?usp=sharing
Unfortunately this causes lots of apps that rely on their own libraries in system/lib to not work any more as they don't have permission to access those files.
To fix it, you can add FTMC as a system app together with the extracted lib/arm files from the apk to /system/app/FTMC.
Under this folder must be a FTMC.apk and /lib/arm/*.so files.
Use an app like MiXplorer so the files have the correct rights automatically.
You will have to be rooted to do this.
Your videos will then play correctly and it will fix the error in your logs.Last edited by mo123; 26 December 2017, 06:53.
Originally posted by dovento View PostHello!
In andriod 7.1 I have to disable all video accelerations to work ...
Is there any upgrade for hardware video acceleration (mediaCodec)? or is there another solution?
thank you
It should also work on Amlogic devices if you have that instead.
Then you can use AMLCodec acceleration.
Look at my solution above.
Thank you
Originally posted by dovento View Postyou can explain better. my English is not the best (I'm Portuguese) and there are situations that I do not understand 100%
"You can even open apk file as zip file in MiXplorer" which apk? apk FTMC?
Open MiXplorer - Download from here https://forum.xda-developers.com/att...5&d=1512240951
Copy FTMC.apk to /downloads or /internal_storage/downloads folder on your tv box.
Rename it FTMC.apk if it has a longer name.
Locate FTMC.apk in Downloads folder, long press it and at the top menu select extract to extract the whole apk
Rename extracted folder /lib/armeabi-v7a to /lib/arm
(You can also do all these steps of extracting the app on a PC and copy it to a flash drive but it might cause problems with correct permissions for files)
Now create a new Folder under /system/apps folder where other apps are, called FTMC.
Now copy FTMC.apk from Downloads folder to this folder.
Now copy whole extracted lib folder in Downloads folder to /system/apps/FTMC folder.
So there will be a folder /system/apps/FTMC/lib/arm/ then there will be lots of so files there.
You can delete the files in the Downloads folder now.
Now Restart your device
FTMC will show a new app icon in your launcher and will not crash if you play a video with amlcodec turned on.
Google introduced public libraries in Android Nougat so vendor libraries can't be loaded by apps any more for improved security.
but the problem of FTMC closed is still exist.
Maybe Cloudnetgo CR19 and H96 MAX is different.
(Cloudnetgo CR19 really could boot and shutdown normally by remote control.)
Maybe someday I make a factory reset and do the way again would be some different result.
Hi Superceleron, Thanks for FTMC, its extended the life of my android boxes. Is there any way to get the official kodi krypton repository? One of the add ons I like (RTP Play) moved to the krypton repo and now I can't watch it anymore.Last edited by m.ermantraut; 31 December 2017, 02:44.
Must be rooted
is a box problem?
it`s possible download to firmware with android 6.0? (I can no longer find this firmware...)
Thank you!
There are currently 2117 users online. 1 members and 2116 guests.
