FTMC Jarvis 16.2.31
Hi i have the last FTMC Arm General/AML 16.2.31 in my 2 boxes beeling gt1 ultimate & ZidooX8 .
I have a "ready build" from Greece named moonlight from www. grecotm .com .
I have a strange issue .
If i choose to manual update add-on the screen after update --->select version have no letters for repos ....
look the images .
In kodi 17.4 the same build have normal look .
Any suggestions ?
Thanks a lotYou may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
Originally posted by OriginalD View PostThanks for creating this. I am having an issue with FTMC on HiMedia H8 Android 5.1. 4K displays properly but no audio pass thru. Any help would be appreciated. This is a RK3368 device.
Try replacing these two .so files (make sure that the permissions remain the same) and see if it works then.
And make sure that your firmware passthrough setting in on (if it is present)
https://github.com/JamesLinEngineer/RKMC/tree/Jarvis/RKMC-Patches/rk3368/Android5.1R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
It will be an issue with your firmware.
Also, I do have the pass thru enabled in FTMC. Please note, the video does play, just no audio on digital. Stereo works fine.
I'll try replacing the files again and applying the permissions. If you are so kind to let me know what they should be.
Thanks bluesmanuk . I did try replacing the .SO from the location you mentioned but didn't check the permissions. What should they be?
You will need to set passthrough in the firmware as well as FTMC unless the firmware is set to auto detect audio output.
Hello. after a lot of work now The FTMC player works really well on the old android running 4.4.2. Question, I have newer android players (android 7.2) running Kodi 17.3. I like how the FTMC player works. Could I use FTMC in the place of Kodi 17.3 (on the box running 17.3). ? or would it be better to stay with Kodi 17.3 ? thanks
There are currently 2431 users online. 1 members and 2430 guests.
