FTMC Jarvis 16.2.31
Build 25 is the first version of ftmc I install.
I must say it works very well.
I am using the generic/am build on a s912 box.
Under settings-> video there is a Rkcodec menu instead of the acceleration one.
I thought I installed the rk version, but I redownloaded and reinstalled and the result is the same.
Is it normal?
My regards.
Good day,
I have a fork of kodi, but when I added python 2.7.12 to the depends and everywhere else needed to be tagged at i get a, "no rule to make target 'python2.7.a' so it fails to compile python. I didnt know if thats something you could help me out with or if i should create a new thread.
Also thx for your hard work you guys do here!
Originally posted by otchill View Postguys,
I have got minix neo X7 with RK3188 chipset, is it possible to use acceleration mode in this device? I downloaded RK build 25 and it seems very good.
But normal 720p video playback will still be fine on RK3188.
There are currently 3414 users online. 3 members and 3411 guests.
