PS: It's a shame that the support for this box is so bad, on the hardware side it has got great potential.
FTMC Jarvis 16.2.31
ti71ti I'm using build 25 in my RKM MK68 on FW SC-1.3C without any problem. I have tested it on an LED IPS Dell Monitor, Samsung LED, LG Plasma and in an old TFT-LCD. Always tested without passthrough or superb sound system, just built-in or external low-cost speakers. I have to admit that a month ago I was having a lot of problems that i reported here, but i tried with different settings and I solved the problems. In "Acceleration" section i have enabled "... - MediaCodec (Surface)" (i know that it shouldn't be enabled, but it works better for me) and in "RKCodec" section I have only enabled "Accelerate RKCodec" and "Accelerate Mpeg1/2" (just because this option CAN'T STAY DISABLED, it might be a bug but i'm not experiencing errors related to this). If you are experiencing problems only with some videos then you should take a look at the sound settings on those videos.
Originally posted by kerenmac View Postti71ti I'm using build 25 in my RKM MK68 on FW SC-1.3C without any problem. I have tested it on an LED IPS Dell Monitor, Samsung LED, LG Plasma and in an old TFT-LCD. Always tested without passthrough or superb sound system, just built-in or external low-cost speakers. I have to admit that a month ago I was having a lot of problems that i reported here, but i tried with different settings and I solved the problems. In "Acceleration" section i have enabled "... - MediaCodec (Surface)" (i know that it shouldn't be enabled, but it works better for me) and in "RKCodec" section I have only enabled "Accelerate RKCodec" and "Accelerate Mpeg1/2" (just because this option CAN'T STAY DISABLED, it might be a bug but i'm not experiencing errors related to this). If you are experiencing problems only with some videos then you should take a look at the sound settings on those videos.
The 2 of you can send me a PM.
I want to put together a new M68 MM firmware this week and will need users to test, will open a new thread for it.
Will need the stock firmware and wifi chip as there are 2 different wifi's for the M68 board and picture of the remote.
If FTMC v26 is released I can also put it in the firmware, otherwise will use RKMC for now
I think new firmware should improve FTMC or other Kodi's performance quite a lot on that device.
kerenmac ti71ti
well i will try to rls it friday but i cant promise it!
I tell I will release something in a day and then so much happens and then it's already a couple of days later
But whenever you can release v26, it will be great and worth the wait.
Link not working.
Is this the one?
http://distribution.bbb3d.renderfarming.net/video/mp4/bbb_sunflower_2160p_30fps_normal.mp4
Originally posted by superceleron View PostWell that file is h264, and amcodec cant do 4k h264 it gives a blank screen! you need to use mediacodec on that type of files!
kerenmac
yesterday i try to do clean install krypton without migrating any .xml from previous install.. At first stream it did happen once... But only once... Then i try again without restarting the box. Now it work like charm... All video i play are only come from exodus or specto.. When it happen, all stream are affected...
mo123
honestly my box are generic... But the board are similar to mk68
and i lost my stock firmware lol... Wifi chip AP6335
here is the pic
superceleron
everytime i turn rkcodec... When i start to stream the kodi force restart... Is that normal?
There are currently 1955 users online. 1 members and 1954 guests.
