My FTMC is always close alone and says the application was stopped, if i upgrading to build 25 solves the problem? If I upgrade do I lose all information and add-ons? If anyone knows how to solve the problem, thank you.
FTMC Jarvis 16.2.31
Hi superceleron...
i have facing this audio problem which i cant identified...
can you please tell me what kind of problem is?
and how to solve it?
it only solved by restarting the android box.. But just awhile the problem back again..
im using rkm mk68 with your cfw sc1.3.
i already try krypton 17.1 ftmc25
problem still not solved...
even if i using the sc kodi which preinstalled with your cfw
please help
thank you
here is my log
please help
thank you
here is my log
https://goo.gl/sdlEWb
thanks for replying me...
Im using default output on android setting.
on ftmc
video source are from exodus or specto
I sent a patch to superceleron that fixes it that he will include in FTMC v26.
Hope it can be soon
If using pass-through try RKMC for now.
You must also enable HDMI Bitstream in Android Audio Settings.
Your firmware is also more than 1 year old and probably missing the latest RKMC patches.
bluesmanuk mo123 i forget to dissable pass trough last night.. Try to see if it can solve the problem... This problem already happened before i enable the passtrough...
Originally posted by superceleron View PostYes RK passthrough is broken in FTMC build 25 <- down... it wll be fixed in build 26 that i should rls next week, if everything goes as plan!
Which box is recommended by you at that moment? I'd like to buy a box but not sure which is the best. As I see gt1 development is stuck at v8c (don't know your olan to continue) but don't have any info about rk devices. Or any s905x?
Thanks in advance
I have Beelink GT1 box with stock firmware. Instaled FTMC, SPMC and so on and all of them have the same issue. When I try to play some 4K files like big bunny then i see only black screen with audio playing. That is happening only when Amlogic coded acc is enabled. When I disable it then all is normal but I have some shuttering. That is happening with moust 4K files but some of them play nice with acc enabled but all of them play ok with mxplayer or other player on box. Is this FTMC related or Amlogic codec in FTMC? I would try superceleron firmware but I dont know if it is firmware problem or just codec problem.
Thank you.
Originally posted by Fijo1978 View Post
Is this the one?
http://distribution.bbb3d.renderfarming.net/video/mp4/bbb_sunflower_2160p_30fps_normal.mp4R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
There are currently 2851 users online. 1 members and 2850 guests.
