FTMC Jarvis 16.2.31
Originally posted by smith2 View Post1st I musy say:
@Superceleron - thanks for your work producing this marvel !!
Now...
Call me stupid - but I sincerely had no idea that FTMC has a home here at FreakTab - the 'FT' part just did not occur to me...duh.
I have an MXQ TV Box with Kodi 16.0 & Android 4.4.2 .
Will soon upgrade it to FTMC.
Hoping -very- much to be able to use the library & other data from Kodi in FTMC.
I searched here but got loads of non-specific results; searched the web and found this:
Which insists=> Before you begin,make sure you have COMMUNITY PORTAL INSTALLED
Whatever that is ??
And it is aimed at Kodi 16.1, which I do not have.
So I ask, please:
Is it workable to just copy in a backup of my org.xbmc.xbmc directory, will it re-use my settings, add-ons & library - OR:
Is there a better way to backup & restore that stuff after installing FTMC to get all that stuff back as its been ??
Thanks for any helpful replies !!
And that is it! very simple!
Superb !!:
Originally posted by superceleron View PostJust rename (before you execute ftmc the 1º time)"org.xbmc.xbmc" to "org.xbmc.ftmc", inside you see "files" and inside that one ".kodi" or ".xbmc" (you need to enable view hidden files) and rename to".ftmc"
Originally posted by minixfreak View PostI'm getting dts drop outs pass through ..... ? Using minix u1 012 firmware
But dts drop outs looks like a fw problem, i know that some fw have that problem!
Theirs a hack for it(general s9xx hack) i think, search the forum.
Originally posted by kerenmac View Postsuperceleron I have built an installable zip with some changes for the Confluence ZEITGEIST skin. I have tested them over the last weeks, but i got some free time today and decided to share them (i have had to clean it as in my custom mod it was quite "dirty", but i think that everything is correct). These are the changes:
- The clock now has seconds. It can be disabled in the skin settings.
- Home addons are bigger.
- Home addons now appear centered when being more than 4.
- Login screen has Confluence original background. (In FTMC the original black background was replaced with the stock Confluence background, so this change does nothing)
- Startup focused home section can be selected in the skin settings. NOTE: If you enable or disable a Home section it is necessary to exit and enter again in skin settings in order to reload the new available home sections.
- In “Wide List” viewmode the list icons are a little bit bigger and the aspect ratio will be kept instead of being scaled in order to have a better look. This means that small posters will be resized instead of being cut.
Link: http://s000.tinyupload.com/?file_id=09840154961898574745
NOTE 1: Changes were made over the stock skin of FTMC (build 26).
NOTE 2: The skin is still linked to the official repo so if a new update comes out it will be overwritten if automatic updates are switched on.
Enjoy!
Originally posted by bifftaz1 View PostWorking great on my very old MXQ box. Thanks superceleron
This is simply awesome, thanks superceleron .
I am running this on a Minix X8-H+. The picture quality using the AML codec is superior compared Medicodec, no question, and this version 26 seems the most 'stable' yet in delivering smooth video with minimal drops etc.
This is playing videos smoothly that other forks just fell to pieces with.
Only minor bug I have seen is that the SD, HD indicator does not come up for each video until it has been opened, rather than being scanned when added to the library. This happened in Kodi/SPMC at one point.
There are currently 1630 users online. 1 members and 1629 guests.
