FTMC Jarvis 16.2.31
Originally posted by 007 View Posteach time i tested i factory reset the boxes, then installed ftmc 26 then added fusion source, installed indigo, installed exodus
if it is just me this is weird because ive also used it on different hardware.
SOCs i used were RK3368 and S905-B
very diffferent SOC
both android 5.1
both 2gb ram
with the rk3368 i even did it on a brand new out of the box powered on the first time HiMedia H8 Plus, and then I upgraded the firmware to latest build factory reset and try again.
Maybe coincidence that its my specific devices.
I will also be trying it on a Brand new Mygica 1900 pro tonight Ill report back.
Im picking up the mygica in 1 hour but then I gotta wait till after work to test.
Not complaining I love FTMC. Even with the bug.
Ill take a video of my next test and upload it and a log if you like
@superceleron
Hey man great work can't thank you enough u saved us.
Umm regarding the exodus issue, i also have a problem when i pause it for a bit and continue again, it crashes or exit the video.
As far as I remember, this used to happened on earlier releases from kodi, but after using spmc it was flawless, but now I'm having the same problem again.
Cheers mate for ur hard work.
Sent from my GT-I9505 using Tapatalk
Hi. Thanks for all your work on this. Only one problem. with ftmc 25 I was able to launch ftmc with android ir remote tv button. now with version 26 since you changed package name and location it won't launch anymore. can you make next version with kodi package name and location so remote will work? Thanks
But i need logs...
Weird thing is that i dont have the problem....
Originally posted by ssevan View PostHi. Thanks for all your work on this. Only one problem. with ftmc 25 I was able to launch ftmc with android ir remote tv button. now with version 26 since you changed package name and location it won't launch anymore. can you make next version with kodi package name and location so remote will work? Thanks
Hi Superceleron, i just installed the new version, after i do a backup, and now i cant get the backup addon on kodi addon repository , the message that give me is that cant connet to the repository
any ideas?? thks again
P.S. i try all so to install from a zip file the backup addon , and gave me the error message, of wrong dependicies
There are currently 2499 users online. 1 members and 2498 guests.
