Sent from my SM-N900W8 using Tapatalk
FTMC Jarvis 16.2.31
superceleron Is there also an Allwinner A10 build available? Great that you support Android 4.X
Originally posted by W00fer View Postsuperceleron Is there also an Allwinner A10 build available? Great that you support Android 4.X
Originally posted by Esbruga View PostHi!
First of all, thanks for the great work on FTMC. Has anyone tried using "IPTV Simple Client" in the new version? I can not make it work.
a few pages back!
that would be the general/aml build, but specific for Allwinner devices like RK one... nop!
Would love to run it on my Allwinner box but it has no Kodi for Linux due to hardware acceleration not present in 4.x kernels.
I'm not sure if is the right place. I have read though about 30 odd pages on this topic hoping someone else had the same issue but figured I would ask as I couldn't find anything.
I have a GPD Q9 tablet with KitKat 4.4.4 on it and tried the update build 28 but couldn't get it to work as it would show the FTMC screen with a progress bar but then would crash after it had finished saying "Ftmc has stopped". So I decided to work my way back through the builds and surprise 23 and 24 worked no problems but nothing newer would work.
Now I don't know how to pull any log files(if I had instructions, no problems) but would like to see if I could get it to work or if I had done something wrong. If I could help in any way or get some help on this issue that would be brilliant.
Originally posted by cdzo72 View PostHas a new version been released to patch the security concerns that Kodi 17.3 will be taking care of? Right now I'm running the Mygica apk and those boys haven't moved a muscle so I'm looking for something to move onto.
Originally posted by android_dev View Post
Thanks. I found the following link : http://freaktab.org/d93ea810f5de9ae2 - will this always be up to date, or will a new link be available for newer versions. I had read you are planning on getting it into version control. Has that been done yet?
And it will be a newer link for up to date versions when i can!
Would it be hard to replace the LIBVDPAU etc by the various patched ones?
Originally posted by fenixguyver View PostI'm not sure if is the right place. I have read though about 30 odd pages on this topic hoping someone else had the same issue but figured I would ask as I couldn't find anything.
But without a log its hard to know!
There are currently 4129 users online. 1 members and 4128 guests.
