FTMC Jarvis 16.2.31
    Originally posted by kerenmac View Post
    I don't understand what you mean with updating the libs (wifi libs? I did not know that it's possible to update them). It's an old FW, but very stable, and the box works really nicelly (much much better than the NEXBOX A95X with XannyTech FW).
    I don't check permissions or the format, but normally I use SublimeText 3 (latest version) on MacOS "El Capitan", and "Keka" to make the zip file. I have never seen error messages on the kodi/ftmc log related with permissions. This problems are new for me, I'll look for information.
    the libs that im talking is rk video codec libs!
    hmm dunno about macos i dont touch one in hmmm a few years now lol, so dunno if that editor uses unix text format
      hmm need to check that!
      Queue function is fixed with new update! Thanks!
        With tvaddons being down what other automatic setup wizard would people suggest (or easiest way to update the addons).
          i really dunno m8!
            Install nexflicks
              Smooth comeback. I deserve that.
                I tried to load bubbles. It kept shutting FTMC down when opening the addon. It works fine on Krypton. Perhaps it needs Krypton to work.
                Sent from my SM-N900W8 using Tapatalk
                  SPMC Krypton can be downloaded here.
                  I didn't notice a lot of changes except the power off menu and an accelerate h264/h265 added setting under video.
                  Maybe a FTMC Krypton is possible in the future?
                    sup
                      well ftmc krypton yes is possible, but not on 4.4...
                      But that maybe after the summer, in 3 or 4 months +/-
                        I'm running Arm Rockchip 16.2.29 and when I navigate to the sub-directory where I'd expect to find the equivalent of the standard KODI logfile, there are only files that all have a .fi file extension as is shown in screenshot I've included. So my questions are:
                        1. Where is the logfile located?
                        2. At this time, does anyone intend to take the source from one of the existing log uploading program add-ons and create a logfile uploading add-on for FTMC that would provide the same convenience as the equivalent add-ons do for KODI & SPMC?
                        Thank you superceleron you for this excellent app and the substantial time that you spend answering forum questions.
                          Try using a different file manager like MiXplorer or ES File Explorer perhaps for 1?
                            Yes use another file manager because its there!
                              Below is a screen cap from using ES File Exp. w/ both "Show Hidden Files" and "System Hidden Files" enabled and it is displaying the same files as T.C. file manger did. Which file is the System Logfile?
                                Hmm weird, i need to check it!
