FTMC Jarvis 16.2.31
Going back to the AmCodec discussion and to give you an indication of where a video will play only the sound.
Go to this link
http://downloads.4ksamples.com/downloads/SKYFALL%204K%20(Ultra%20HD)%20(4ksamples.com).mp4
The right click and use the save video option.
Turn on AMCodec ad play the file.
Then turn it off and play again.
Originally posted by mikele View PostI mean I can adjust brighness/contrast with ff encoder, but I can not adjust them with amc or am acceleration hardware encoder is this normal ? (if you disable all your hardware acceleration encoder your video will play with ff software encoder)
Originally posted by minixfreak View Posthey superceleron can you make ftmc 17 ..... you could use mygica 17 which works on older devices and add tweaks from spmc 17 and regualr kodi 17.3
I will make FTMC 17 but for now i think this one still does its job, i still have 1 or 2 more update programmed then is time to leave it and go for 17, since on Android O this FTMC 16 will stop working ok!
Mygica 17 is a piece of crap... is a early beta build of 17, and to make it go from 17 till 17.3(17.4 should be out in 1 or 2 months maybe less) is a big big task for only 1 person and you will lose android 4 support that is for sure!
Hello people!
Please, someone can help me?
I have FTMC installed over a amlogic MXIII G. When i trie to load the MetalliQ add-on it stops with most of the "players" (only one is working). It was not an aaddon problem because it work well on kodi , just in FTMC is not...
Thanks in advance.
Regards from Portugal.
Thanks in advance.
Need a log to see where is the problem!
Well... this is the addon -> http://noobsandnerds.com/latest/?p=4108 and the log file is here -> http://tinyurl.com/y7h4ooc7
I don't now if the log shows something because all ftmc stops and i have to force close it...
When i try to play a movie with a "player" (Elysium for example) inside Metaliq, all FTMC stop/block. (The only "player that works is BOB)
But in the original Kodi all of the "Players" work...
Damn... i dont want Kodi, FTMC is the only one that works great with my Box... but i love MetaliQ
Great work with FTMC by the way
There are currently 1848 users online. 3 members and 1845 guests.
