FTMC Jarvis 16.2.31
Originally posted by achilles_t7 View PostYou are doing an incredible job! I had many many problems with KODI 17, while FTMC works amazigly well with my device. I have 2 questions:
1. How can I donate?
2. Can I install an FTMC update on top of the old version without loosing my settings and addons?
Thank you!
2º only from build 27 -> up! older than that you neeed to do some folder renaming!
Originally posted by JoseM View Postanyone here watch (test) 1080p HEVC 10bit files ? they never play smooth for me no matter which firmware or video player i'm using
1º Donation Link Press Here
Here plays just fine! even 4k ones!
I installed it on one of my S912 Boxes the only Difference that I have found is that the Enable Airplay support is no longer there and there is another option Share my libraries was either added or is now Displayed.
As far as function goes it is still the Same Main Menu Videos/Files/Add videos.../Browse/UPnP devices but that is it you still have to add it by just going to that option and clicking OK then OK again you get the Dialog Box that says "Unable to connect" click Yes and it will add it to your sources but you still have to go back to SYSTEM/Services/Enable UPnP support and select that option to be able to connect to and other UPnP Servers.
Still Broken.
Originally posted by superceleron View PostThat is the intended way!
Well we cant please all ppl!
I can work around it but the Average Android user will never figure it out.
If you are using FTMC older before the Patch from SPMC all you have to do is goto Menu Videos/Files/Add videos.../Browse/UPnP devices click on UPnP and you either get a list of available UPnP Server or nothing if there are none.
The SPMC Patched FTMC you do the same thing and when you click on UPnP nothing happens, While it is highlighted you can click OK this will bring up the add option but when you goto save it complains that Unable to connect " Couldn't retrieve directory information. This could be due to the network not being connected. Whould you like to add it anyway? Click Yes and it adds it to the sources.xml file
and you still have to go back to setting and Enable UPnP support before you can connect to any UPnP servers.
After enabling UPnP support the UPnP option disappears from the Videos/Files/Browse
It has always worked by just going to Videos/Files/Browse/UPnP devices Before the SPMC Patch that added Airplay to the Setting/Services Menu
Kodi still works this way also RKMC still works this way only SPMC and FTMC seem to be Broken.
Originally posted by superceleron View Posti know what you mean, but i like the way koying implemented it is not a bug is... like that!
PS: he just did the same in SPMC krypton!
It is a Bug regarless and I was the First to say that the Same UPnP Bug was in SPMC 17 "Broken is Broken" no matter how you look at it.
Unless you are out to Confuse the Novice user that is.
There are currently 2161 users online. 1 members and 2160 guests.
