FTMC Jarvis 16.2.31
Originally posted by superceleron View Postyes i did check it, and i dint nothing wrong with it... so dunno m8
And if you have a RK cpu then you lose passthrough, if you dont use passthrough then you can use it normally
EDIT: It worked, Build 18 installed!
Hi, superceloron and thanks for your work on FTMC and firmware for a number of devcies.
Currently I use FTMS build 18 on AML S912 GT1 box flashed with your firmware v 3. Unfortunately cant get passthrough to work. Any ideas what might be wrong with it?
Thanks in advanceThere is no sp00n ...
Originally posted by misa View PostI got a Himedia H1 (Android 5.1.1) with Rockchip 3229 and RKMC and realy want to change to FTMC. My problem is when I uninstall RKMC (completly) and start the box up again, it's there again. How can I get rid of RKMC and install FTMC?
Passthrough is working beautifully on my MXIII-G II
There are currently 2814 users online. 2 members and 2812 guests.
