FTMC Jarvis 16.2.31
Guest
Originally posted by superceleron View Postyou need a updated rom for FTMC to work ok on RKCodec!
I have also, the z4 box (Z4 TV Box with Rockchip RK3368) and I put on it a stock rom from last year (this : http://chinagadgetsreviews.blogspot....op-511_21.html), but it is not the last one.
I must install the custom rom : http://freaktab.com/forum/tv-player-...368-custom-rom
or this rom from here: http://chinagadgetsreviews.com/downl...z4-tv-box.html
to make my box compatible with your amazing ftmc (rk acceleration)?
Do you know anything esle?
Thank you.
You guys need to search of read more...
start here http://freaktab.com/forum/tv-player-...985#post588985
After that on FTMC dont enable VP9 HW decoding since the 3688 dont have VP9 Support!
Guest
It can be more helpfull if somebody have this box, adn tell us, what firmware use.
Thanks Superceleron fro your answer. In the past, I was try the ugoos and even I put only the system image, I had problems. The box staying open only when I had the cable connected to pc.
I think, many people want to know, what is the best firmware for z4. With the first change I will try the last stock rom as I said before. But I know, that these roms they don't have changes, the guys where create them, they put inside just the newer apks and theirs names or links to drive the people in other site.
We want to know, exactly the firmware (vesrion and link to download) , the way to install and if everything with that works well.
Thank you.
superceleron FTMC supports external media players like HiMedia and Zidoo Kodi media players do? I've love to try MXplayer as external media player. Thanks-Chromecast with Google TV
- Android Q Android 10
Originally posted by eddieaok View PostHi Superceleron I have a question for you
Currently I use SPMC 16.5.5 latest build with the stock firmware 0007 for T95Z Plus.
I'am about to flash your custom v1 ROM for my device.
With the tweaks to your new ROM would I see improvements if I replace SPMC with FTMC.
Ed
Guest
Good morning.
Superceleron, do you know why on my z4 box, on the movies the ftmc don't have all the tools for contrast and brightnes and on my other box gt1 s912 are there?
The correct version for z4 box with the last stock firmware, is? 20? or 17? (I test already with the custom rom from here on z4 (http://freaktab.com/forum/tv-player-...r-update/page1). It was slow even the rk working well. On my gt1 the ftmc is amazing. Soon I will test the z4 stock firmware (november).
Thank you.
Its not there because the guys at RK dint add it
maybe you can open a "issue" in here(this is rk github for rkmc) to see if they add it then i will add it to FTMC: https://github.com/JamesLinEngineer/RKMC/commits/Jarvis
Thank you.
There are currently 1900 users online. 0 members and 1900 guests.
