FTMC Jarvis 16.2.31
Originally posted by kerenmac View Post
Please, could someone help me with this doubts, something, just to know if it would be a good idea to move to FTMC or even if I can install it in my box. Thanks.
I've transferred my Kodi setup on my Windows-PC to FTMC on my RK-TV-boxes with it.
AUDIO TEST FILES PLAYBACK COMMENTS BAD 1 Dolby Digital Plus 5.1 X the sound cut some time (10 or 15 times in 1 hour) 2 Dolby Digital Plus 7.1 Channel Check 3 Dolby TrueHD 5.1 X the sound cut some time (10 or 15 times in 1 hour) 4 Dolby TrueHD 7.1 Channel Check 5 Dolby ATMOS 'Amaze' Demo 6 Dolby ATMOS '747' Audio Demo 7 Dolby ATMOS 'Helicopter' Audio Demo 8 DTS-HD HRA 5.1 9 DTS-HD HRA 7.1 10 DTS-HD MA 5.1 Channel Check 11 DTS-HD MA 5.1 24-bit 192kHz audio-only sample X the sound cut some time (10 or 15 times in 1 hour) 12 DTS-HD MA 7.1 Speaker Phase 13 DTS-HD MA 7.1 'Dredd' Audio Channel Check 14 DTS:X 'All Around Us' Demo 15 DTS:X 'Gravity' Demo 16 DTS:X 'Movement' Demo 17 LPCM 5.1 18 LPCM 7.1 19 AAC 5.1 20 FLAC 5.1 24-bit 192kHz audio-only sample 21 DTS 5.1 X the sound cut some time (10 or 15 times in 1 hour) Audio Receiver used Yamaha RX-V465 Capabilities(5.1, 7.1, DTS, TrueHD etc.) 5.1 / DD, DD Plus,DD True HD,DTS,DTS HD. Kodi settings used Auto framerate off Pause during refresh rate change Keep audio device alive: never, always, 10 minutes etc. BOX : i68G Firmware : ionix 9.5 FTMC-16.1-armeabi-v7a-Confluence-Build-12 librkffplayer libffmpeg (ugoos_kodi_16.1) same thing Last edited by shivattaque; 22 November 2016, 08:21.
Originally posted by uli-hh View Post
"Backup" addon to backup everything in Kodi and then restore the backup in FTMC is working. Maybe you'll get a message that the backup is from am other version of Kodi but you can ignore that.
I have installed the old advencedsettings.xml, but in FTMC there is no CPU Temperature value, what should i write know to have that value back in System info??
FTMC Build 13 -> http://freak-tab.de/luis/Ftmc/FTMC-1...e-Build-13.apk
Changelog:
Code:[hdmi] fix hdmi 3d switch [rk mpi] init rk mpi decoder base version [logging] close extra log print ADD: [xsp] filter by originaltitle Revert "CHG: [droid;amc] only give priority to surface in 4K" Now that the most bothersome limitations of surface are fixed, revert to giving it prority Display milliseconds in log file FIX: [droid] use CLOCK_MONOTONIC, as OS FIX: [amc] no need to update texture when discarding buffer FIX: [amc] initialize m_codec changed, expand zerba check to all platforms core: fixed ZebraListAccessCheck, need to compare paths using results from realpath, else they might not match GUIFontTTFGL: Fix texture leak in subtitles With mkv file with S_TEXT/UTF8, we leak one texture of 1024x64x32bpp (256K) for every file that is played. DVDOverlaySSA: Fix Leak with SSA subtitles This fixes the long standing memory leak: http://trac.kodi.tv/ticket/15820 CDVDSubtitlesLibass is reference counted and only releases libass reasources (typically hundreds of MBs) when count gets to zero. But the resource is incorrectly acquired after being created with a reference count of zero, so is never released.
I have flashed my GT1 with superceleron 's beta firmware, which includes FTMC. Unfortunately FTMC does not work with my USB soundcard, meanwhile the Android system works with it. Any settings I mis?
Originally posted by superceleron View PostFTMC Build 13 -> http://freak-tab.de/luis/Ftmc/FTMC-1...e-Build-13.apk
Changelog:
The version 12 i installed over the 11th ...can i do the same thing with this one or i have to uninstall the old ones?¿?...
2:
Is there any method for non rooted android tv to replace and update the 2 files(librkffplayer.so & libffmpeg.so) into /system/lib.?¿?
3:
Thanks for your hard WORK...without this FTMC i wouldn't use my android tv well...
You can´t imagine how much you help me with this...and for that...THANKS A LOT!!!!!
Hi, I have successfully installed the 13 version over the 12, the first two tries it crashed but have never happened again. I thought that this version would solve a problem which comes from a long time ago, but it does not. This errors appear quite a lot, specially at the start:
- error reading /sys/class/display/display0.HDMI/modes
- error reading /sys/class/display/display0.HDMI/3dmode
The thing is that those folder don't exist, and I have searched for a solution. It seems to be a problem that Kodi has had for over a year, and the solution could be to change those path for the correct ones:
- /sys/class/display/HDMI/modes
- /sys/class/display/HDMI/3dmode
Can this be solved? Thanks
Originally posted by WAIKIKI728 View Post
1:
2:
3:
2º Sorry but nounless you know how to edit roms!
3º many thaks
Originally posted by kerenmac View PostHi, I have successfully installed the 13 version over the 12, the first two tries it crashed but have never happened again. I thought that this version would solve a problem which comes from a long time ago, but it does not. This errors appear quite a lot, specially at the start:
Sorry
That's why I wont buy any RK devices any more, or at least nothing made by RKM, worst support ever!
I'm having a quite annoying bug with FTMC; When i click the return button in the videos menu (or any other) after some seconds it automatically goes back to the latest window or replays a video or music which i had just stopped. Why is this happening?
thanks
hi superceleron and thanx for your time, i have a MK808B Plus withe your rom/kodi and it's work well in DTS and DD
but this box i68G or other RK3368 it's shit, sorry for my word.
but i buy 72€ and i would like to see this thing work.
I said it just for my nerves.
Anyway, for version 13 the sound and image always jumps 2 to 3 times per hour.
i68G
ionix 9.5
librkffplayer ok
libffmpeg ok
There are currently 1494 users online. 1 members and 1493 guests.
