FTMC Jarvis 16.2.31
    But here is the last build i made...
    Changelog:
    Code:
    DVDVideoCodecAmlogic: Do not H/W decode Hi10P h264
    [GUIFont] - the BufferHandle is a GLUInt for gl and gles and a void * for dx
    [GUIFont] - fixed warning about BufferHandle initialisation
    [GUIFont] - make BufferHandle explicit GLuint, use initializer consistently
    FIX: DT_SONAME warning
    [FIX] Ignore MEDIA_BUTTON intent received while not playing
    disable plugin caching
    FIX: [droid] never try to do a lib copy
    FIX: [droid] libmodplug.so was missing since... ever
    FIX: [droid] more DT_SONAME
    [FIX]: fixed crash, GetStereoModeFlags. In odd cases, mode can be empty
    disable screensaver if slideshow is playing, tvos/android
      THANKS!!!!!..Let´s how it works or what improves with rockchip and Leotec android tv
        Hi, after tested Build 10 here is my return: sound skips occasionally with the video but sometimes returns after 2 or 5 seconds, with any sound codec.
        (i68G with TronZid 9.5)
          FTMC Build 11
          Changelog:
          Code:
          Updates to librtmp - KSV Fixes
          FIX: better Randomize()
          FIX: remove all random_shuffle
          FIXUP: randomize
          FIX: [droid] don't try /proc/self/exe (selinux)
          [VP6] send VP6 to soft decoder
          [Thumb] when video is playing do not extract thumb
          [Audio] after decode audio frame sleep 1ms
          [Thread] set thread name for some threads
          FIX: [droid] enable system screensaver everywhere
          DVDVideoCodecAmlogic: Do not H/W decode 10-bit HEVC if hardware doesn't support it
          DVDVideoCodecAmlogic: Add more unsupported H264 formats to HW decoding blacklist
          10bit video do not extract video thumb, because of need use more memory for ffmpeg decoder, make cause out of memory
          [video/rm] fix some video rm file could not play
          http://freak-tab.de/luis/Ftmc/FTMC-1...e-Build-11.apk
            Can i install it over the old ones?¿?...
            With all the updates i just see that if i activate rockchip acceleration i can´t play any mkv files...is that normal?¿?
              No, you also have to copy the 2 files(librkffplayer.so & libffmpeg.so) from the link below into /system/lib.
              Just make sure it has the same permissions as the files already there or use MiXplorer  file manager that automatically sets the correct file permissions otherwise you might get a bootloop.
                I can´t copy the files..i don´t have root in my android tv..and i don´t know what i am doing wrong...
                  The same thing happens to me...
                  P.D.:
                  Sorry to post times
                    Like i hace just opened a new threat and i am around here i spend my time to upload several photos with the last FTMC...
                    At least for me the best version of Freakteab is FTMC Build 11 without problems with sound of the films..
                    P.D:
                    I wonder why some screenshots are bigger than other ones if i always select full size in my post
                      Try not selecting a size, just post it and see what happens.
                          Hi mo123, would be great if we have a script to set proper permissions. Thanks!
                          Tronsmart Orion R68 Meta
                          CS968 -> HTC_T018 v4 20131216 with MTK
                          GM282 (aka CX 919 II aka J22) - dead
                            the build 11 is better except for the DST HD, DD True HD and DD +(E-AC-3), for the video h264 it's ok juste a little cut.
                            i68 G (9.5)
                              Another new build...
                              Changelog:
                              Code:
                              [AndroidDyload]: fix crash when dlopen fail in close function
                              [AudioTrack]: Add Android6.0 IEC61937 define
                              upstream sync, fixed: Low readrate error toast could show when performing e.g. small stepping
                              core: add http DELETE handling
                              [fix] crash on UnShuffle ... davilla says : std::sort requires a sort function that creates a strict-weak ordering
                              fixed, big seek is like a chapter, also do a m_callback.OnPlayBackSeek there too
                              fixed, closed caption for EIA-608/EIA-708. Not sure how this ever worked. Finding a cc stream then calling OpenDefaultStreams(false) will delete/create m_pCCDemuxer so m_pCCDemuxer->GetStream(pkt->iStreamId) fails as there are no CC streams anymore
                              FIX: [droid;egl] quirk is not needed and problematic
                              fixed, mem leak. need to release the msg here as nothing else will handle it
                              FIX: [rar] deadlock with cbr + net vfs (credit @notspiff)
                              FIX: [jpegio] return original size
                              [WIP] Proper eComics mode
                              ADD: [droid;key] channel up/down
                              enjoy.
                                Thanks...is it necessary to update the 2 files(librkffplayer.so & libffmpeg.so)?¿?¿?
