FTMC Jarvis 16.2.31
Originally posted by freakkid View PostI think he means where are the libffmpeg.so and librkffplayer.so files to replace the ones in "system/lib/" folder....Thanx again for working on this!!
More code ported from spmc, thks koying for the code!
http://freak-tab.de/luis/Ftmc/FTMC-1...7a-Build-8.apk
Changelog:
Code:FIXUP: GLES HQ scalers warning CHG: add streaminfo string to all streams CHG: [bitstreamstats] allow to force a calculation (if < 2 sec) VideoPlayer: refactor enable/disable demux streams Add a demuxer that manages demuxing of multiple streams/files at once. removed boost for good CHG: get rid of boost multi_index CHG: get rid of boost circular_buffer FIX: no stoi remove boost::lexical_cast steal sha1 from boost, another boost-izum dies FIX: Only give error loading addon settings if there actually are some to load
well if it is that... here : https://github.com/JamesLinEngineer/...s/RKMC-Patches
Yesterday I backup the old librkffplayer.so and updated the librkffplayer.so (found and downloaded from internet) on my Tronsmart RK3288 Android 4.4 and now the box refused to boot. May be due to the wrong version of the librkfflpayer.
Can you please help me to restore the backup ? Or I have to flash the rom and loose all Kodi setup?
Again thanks a lot for your help.
Originally posted by sviet2k View Post
Thanks a lot superceleron. It's is that but it'a a little bit late for me.
Better to upgrade your firmware.
Unfortunately Tronsmart abandoned the R68 Lollipop firmware long ago,
You might be able to install Wasser Lollipop firmware from Beelink that already have the librkffplayer files included.
There are currently 1903 users online. 2 members and 1901 guests.
