FTMC Jarvis 16.2.31
Superceleron. Is it possible to implement a hack for s905x to echo 2 >/sys/class/audiodsp/digital_codec to fix DTS dropouts. Or since latest stable kodi seems to work best build it with this hack for this box. I haven't tested ftmc yet to see how it does. This is hypothetical at this point.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by minixfreak View Posti tried playing 4k movie and it freezes ...... just sound and black background ..,.. movie is x265 codec 10bit .... also im on stock tronsmart 209l firmware r68g
New Version...... this time 2 versions... 1 with the default Confluence skin and the other with AeonNox skin, since some ppl asked to leave the default one!
Changelog:
Code:Revert "Add a demuxer that manages demuxing of multiple streams/files at once." FIXUP: only trigger resync if audio is really starved ADD: [addon;repo] add "xbmc.addon.datasource" extension to specifiy source per addon This allows to source the addons from their respective github repo FIX: [droid] trap case when an event device id is not found Shouldn't happen, but it does, apparently... FIX: ensure real filename from videodb in playlists FIX: protect our GUID CHG: [amc] Surface priority only if vid size > gui size FIX: redact user/passwd from advancedlogging debug log Make CEGLNativeTypeAmlogic compatible with Amlogic S905 SoC running kernel 3.14.
There are currently 2760 users online. 0 members and 2760 guests.
