Please do you have a last libffmpeg and librkffplayer work on RK3368 because i have the same sound problem again.
FTMC Jarvis 16.2.31
https://github.com/JamesLinEngineer/RKMC/tree/Jarvis/RKMC-Patches/rk3368R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
These seem to be the latest from Rockchip
hi,
I test actually "SPMC 16.5.3" and FTMC 16. Just to say that my first return on SPMC are positive, no break in Dolbi Digital (not yet tested the DTS) "all the tests are in hdmi bitstream" only difference is hardware decoding which is not possible on SPMC. You may be looking at their code to find out why this works best with SPMC.
At first glance only the DTS HD does not work on SPMC, I have not tested long enough to see if there is sound cut.Last edited by shivattaque; 20 December 2016, 09:57.
I do not know if it is the solution but the choice "Passthrough RAW and ICE" it's not bad idea.
And about another test with a 1080p 10bits 2.0 manga On SPMC it's beautiful but the sound is not stalled because it rows, on FTMC the sound is good but the image drool.
Thank you for your time, I will give my return hoping to be useful as soon as possible for future version.
"H264 MPEG-4 AVC 1920x1080 Planar 4:2:0 10-bits LE"
Sorry, RK3368, i68G / IONIX 9.5Last edited by shivattaque; 21 December 2016, 22:47.
Originally posted by shivattaque View Post"H264 MPEG-4 AVC 1920x1080 Planar 4:2:0 10-bits LE"
So it will be played back by the CPU and be choppy with video artefacts.
Only RK3229 can play H264 10-bit.
There are currently 1599 users online. 0 members and 1599 guests.
