FTMC Jarvis 16.2.31
Been playing with sftp streaming the last days and have discovered that the FTMC client (once stop pushed) does not send a correct signal to server, and therefore the server and FTMC client are still in
data exchange, which results in network congestion and ALSO inability of FTMC to exit (close process).
It's repeatable and verified from several different implementations of sftp servers.
Hope this could help in solving this bug.
Hi all,
Loving my new android tv box T95Z running Superceleron's custom ROM from this forum. [ROM] Sunvell T95Z PLUS / T95K PRO / T95U PRO - Superceleron V1 Final ROM
This ROM solved a bunch of crazy glitches with the factory ROM!! Many thanks to Superceleron et al!!
Anyway - I have a weird bluetooth issue. I have a bluetooth headset tied to my android box and it works for other applications. It also works within FTMC if I choose music like from Shoutcast.
BUT - if I choose any video addon like Youtube it doesn't work. Ironically - the sound goes to the headset for 1 second then no sound at all. The audio does not revert to the TV or anything. If I disconnect the headset - the video stops and if you restart - audio goes back through the TV.
I tried audio passthrough - nothing changed.
I updated FTMC to rev 20 and still not working.
Previous to updating the ROM to Superceleron - I can confirm that KODI 16.1 did not work either.
Any ideas to try?
Thanks in advance!
Superceleron! Man - You are right here! Love that! I am still new here - but thank you thank you so much! Your ROM solved a bunch of crazyiness in this box.
Anyway - I did some more googling and found http://forum.kodi.tv/showthread.php?...225#pid2373225
Short answer - if you pause the video 4 times (pause/play/pause/play/pause/play/pause/play) the audio starts to work. Sometimes 3 pauses works...
Not sure how that fixes it but it does. I tried pausing once for a long time - thinking it was some audio buffer issue? But that doesn't do it.
Oh and - one other clue - it doesn't seem to matter if I have audio passthrough selected or not. Same fix either way.
Crazyiest thing - just thought I'd update the blog so the work around is easier to find.
Thanks again,
I came upon a strange issue today: I have paired my bt headset with my t95z plus. I can hear the system sounds. When I start kodi, the sounds with switching, changing apps etc are hearable, but no sound with movie playback. But: if I pause the playback 3 times, the audio is ok. Don't ask me about the quality, I use regulat stereo bt headset.
What can cause this issue?Sunvell T95Z Plus
Originally posted by Foolproof View PostI have Evolveo Android box H8, I think it has chip AArch 64 and Android 6. I have installed Kodi 17 RC4 and SPMC 16.5.5 too..
When I try install FTMC it offers me an upgrade. I do not know what will be with upgraded, Kodi or SPMC? I do not want to experiment.
Thanks for the reply.
SPMC will be unaffected.
There are currently 1918 users online. 3 members and 1915 guests.
