FTMC Jarvis 16.2.31
    For whatever reason I am having Problems with UPNP on almost all of RK Players since Build 21 UPNP is not Found.
    The List Of Players are R-BOX Plus 2gb/16gb rk3229, MXRPro 2gb/8gb rk3229, Z4 rk3368, GeekBox rk3368, Rikomagic MK902II rk3288 All are running 5.1.1 except for the Geekbox it is 6.0.1
    The Only one I have Build 22 working on is a Rikomagic V5 Stick rk3288, the Odd part is it is Flashed with the MK902II 20160722 Firmware just Like the MK902II that has the UPNP Problem.
    All Player have the Most Recent Firmware that I am aware of the Z4 is running the Ugoos 1.5 Mod.
    I can revert to any Build before 21 and UPNP Works Fine.
    Is anyone else having any UPNP Issues on the RK Players???
      Strange, but yes there was a lot of changes made to UPNP.
      I will try with some time see where is the problem!
        This may or may not help but I checked the V5 Stick and I had did an upgrade to Build 22, In settings Services UPnP/DLNA I enabled AirPlay and UPnP Support then the old Source for the Auto-Discovery works but you can not add any other UPnP servers since that option disappears from Videos, Files, Add videos...
        Verified that adding a UPnP Server to the sources.xml and turning on the options above and the MXRPro box can find the UPnP Servers again.
          hmm strange! but thks for the info
            Hi, for me test 21 well just one thing : in the sounds options i have dts and Dolby digital, no dts hd master and Dolby digital true hd.
            "HDMI bitstream".
              1º use build 22 that build 21 have some "crazy" bugs
              2º its there the name is "Support 8 Channel DTS-HD audio decoding" but if you are using this in one of this "china" boxes forget it you wont be getting DTS HD or Dolby digital True HD... that only on devices with the proper licenses...
                I have i68 G and Before it worked but the HD sound cut.
                now, i don't have HD sound option just dts et DD.
                i use passthrough.
                  Just did the comparation test using the MI Box (Android TV version) by comparing FTMC build 22 and SMPC (latest).
                  FTMC is clearly capable of better reproduction (both 4K video and sound), but it lacks Google's voice search - Could this be implemented?
                  Frame rate switching would be also welcome!
                    i use passthrough.
                    Are you using RK version?
                    Sorry m8 no go, 2 big of a change :/
                    Frame switch is working just fine, well at least on my aml devices!
                      Yes i use RK22.
ID:	625060Click image for larger version
                        You must change to expert mode, no advanced., I think
                          and you say they are on older builds?
                          Show me a pic of that, on older builds!
                            it s no your build but it s same build 17
ID:	625130Click image for larger version
                              Kodi 17 are a lot more advanced than this one and i mean really a lot...
                              So not the same!
                                Updated to build 22. Unfortunately now I loose sound every few seconds even when I am playing AC3 movies. Not sure why this started? It used to be fine. I had issues with DTS but never with AC3. Any suggestions? I could try to switch back to older version maybe that might fix it.
