FTMC Jarvis 16.2.31
Guest
And when I will enable rk again and before I saved for all the settings, it will keep my option?
1) Can I use it on a "Beelink Mini MXIII II" with S905X?
2) For lower brightness have I to enable or change something or by default into FTMC is OK?
3) For AC3 passthrough which sellections have to enable?
Thanks for your marvellous program sir.Last edited by xalaros; 14 January 2017, 10:42.
Someone has made a pull request that solves the problem with the plugins cache https://github.com/xbmc/xbmc/pull/11478
PS: I cant't believe that the reason for disabling the cache was that favourites cache does not work properly. I think that it is an extreme solution.
well it works just fine 1080p h265(4k also ok and 10bits also ok and VP9 4k also ok, you can see my videos of the roms...) in my boxes with FTMC...
And no you cant have kodi 17 and ftmc at the same time, only SPMC+FTMC or Kodi+SPMC.
The refresh sync its there, "system/video/playback" and "adjust display refresh rate".
I wonder if this is the setting that is being referred to.
http://forum.kodi.tv/showthread.php?tid=219796R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Thank you both for the clarification. Too bad they can not co exist. I liked some features of both. Will probably go back to FTMC because the box is not playing it properly even when the file is local as opposed to streaming on the LAN... anyway, it is a h264 (i was incorrect before) @ 1080p @ 23.976 and even my computer which is very powerful has trouble playing it smoothly if i use vlc instead of something with better acceleration to use my gpu...
It is the only file i have ever had trouble with in FTMC but i didn't realzie even VLC on my computer wasn't good at it. i should re encode it or get a better transcoding server app i guess.
Originally posted by bluesmanuk View PostI'd be interested to try the file to see what it does for me if you fancy uploading it somewhere.
It's perfectly work safe.
Originally posted by permabanned_pete View Post
Mods let me know if this isn't allowed to link to torrents like this or just remove my post if so and i'll get the hint.... but i think it's okay to link this.....
There are currently 2445 users online. 0 members and 2445 guests.
